  • July 19, 2025, 02:09:12 AM
Author Topic: Enya 09  (Read 1930 times)
Offline Bill Morell
Enya 09
« on: May 24, 2022, 06:53:34 AM »
What size tank for about 4 minutes? Also what size prop? Thanks in advance.
Bill Morell
Vietnam 72-73
Re: Enya 09
« Reply #1 on: May 24, 2022, 06:56:40 AM »
1-1/2 oz tank and 7-3 prop
Offline Bill Morell
Re: Enya 09
« Reply #2 on: May 24, 2022, 08:10:57 AM »
Thanks!
Bill Morell
Vietnam 72-73
Offline Martin Quartim
    • StuntHobby
Re: Enya 09
« Reply #3 on: May 24, 2022, 09:09:58 AM »
I use 8x4 with my Enya 09 in a RC model and it works better than 7x5 and 7x6. Most people I talk to about the 09 also says the 8x4 works best.  But we all know it depends on model and climate. So try different props.
this guy is sure having fun with it
Martin
Offline GallopingGhostler
Re: Enya 09
« Reply #4 on: May 24, 2022, 11:54:50 AM »
Depends on model of Enya, but yes, the .09-III and later were really good torque engines. Haven't tried an 8x4 prop on mine yet, but on an RC trainer (Hobby Shack foam 40" Cessna 180) for .049, mounted a .09-III TV (1965 model). on 15% nitro with 7x3 prop, it moved out very .049 like. When I put a wood 7x6 prop, then it moved out with authority, became a really nice sport plane. If I had an 8x4 to try, wouldn't surprise me that it would haul good, too.
Peter Chinn in his engine article mentioned that there was no point in trying props smaller than 7x4, because in flight RPM took it beyond the HP curve. He said that it was second powerful to the Cox .09 Tee Dee.
http://sceptreflight.com/Model%20Engine%20Tests/Enya%2009-III%20CL%20&%2009-III%20RC.html
I was further amazed, based on Peter's other reviews on the Fox .15X, that the HP curve is stronger on the Enya. I guess where where people get an impression these cannot perform, is that they utilize too small of props, as though they were Schneurles. HP is developed at a lower RPM.
An interesting find for me was, my Enya .09-III likes lower inertia wood props, is harder to hand start and needle with heavier plastic props. (Don't have an electric starter.)
The earlier Enya .09's including twin stack were less powerful.
    • StuntHobby
Re: Enya 09
« Reply #5 on: May 24, 2022, 04:50:40 PM »
I got this from RC Universe
Offline Bill Morell
Re: Enya 09
« Reply #6 on: May 24, 2022, 07:22:51 PM »
The Enya engine I'm using is a 3001. Very early model.
Bill Morell
Vietnam 72-73
Offline John Park
  • Agricola
Re: Enya 09
« Reply #7 on: May 25, 2022, 02:43:15 AM »
First time I've seen anyone land a Phantom on grass without flipping it over!
Offline Ara Dedekian
  • Ara Dedekian
Re: Enya 09
« Reply #8 on: May 25, 2022, 09:42:33 AM »
      Just returned from my first ever outing with an Enya 09. It was a Mark IV on a wingless estate RC Curtis Robin fuselage (World Engines kit?). I grafted a Sig Rascal wing (50") onto it, fueled up with 10% and couldn't get it off the ground; taxi mode only. In trying various props, a 7x5 seemed to work best, judging by the static thrust. A 7x6 loaded it up and a 7x4 felt weak.
     Amazing that the C/L Phantom took off, I'll have to try more nitro or the Fox 15 Schnurle I have at the ready.
     Ara
    • StuntHobby
Re: Enya 09
« Reply #9 on: May 25, 2022, 08:42:46 PM »
how about a 57" wing model powered by an Enya 09?
 P-51 with an Enya 09 w/ 8x4
Martin
