nope - you aint missing one - the top one only goes from the doubler to the LE of the stab - then you need to cut it and install the last little bit from the stab to the back of the fuse.
the bottom one is the same - is butts up against the rear of the doubler - but goes right through.......another "Wynn" tip here tho - mark where the tailwheel mount goes, and leave the stringer out there also - as fitting the tail wheel plate in with the stringers in place is a PITA
