I have been using the ST.51 since 1994 in a Shark 45, Tom Dixon "Charner" (modified from his Charisma) and a SIG Magnum that weighed 72 ounces. Out of all the props that I have tried over that time, I have liked the APC 12.25/3.75 the best and got the most consistent and repeatable performance from that prop. Depending on the model size and weight, take off RPM is any where from 9800 to 10,000/10,200 range. I also use tube type mufflers, GlowDevil R/C long plugs, and SIG Champion 10% fuel mixed 50/50 with SIG All Castor 10%. This combination was the first that I experienced that worked well in the wind to reduce wind up also. If you need to try an off the shelf three blade prop, try the Master Airscrew 12/6. I went to that one my second Shark 45 to have clearance for a set of shorter landing gear, and clipped it down to 11". I experimented wit re-pitching it, but in the end, the stock prop left alone and cut down gave me a run and performance similar to the APC 12.25/3.75. Line lengths on all models were in the 65 to 68 ft range from handle to fuse center line. I have a Score with a Saito .56 in it, and from what I have observed so far from flying that model, the ST.51 should do well in that air frame also, with similar set ups. Your mileage may vary, but give this a try and see how you like it.
Florissant, MO
