  • July 06, 2025, 07:27:17 PM
Author Topic: engine running  (Read 3689 times)
Offline Bill Mohrbacher
engine running
« on: May 05, 2014, 04:10:18 PM »
The engine running season is about here.  When presenting model engines to the public or to other enthusiasts, it is important that things go well or you will loose your audience.
Therefore meticulous preparation in an organized fashion is required.  One must be sure there is no chance for even the tiniest detail to be overlooked!
Offline Bootlegger
Re: engine running
« Reply #1 on: May 05, 2014, 04:40:23 PM »
 O me o my, which one shall it b??
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline De Hill
Re: engine running
« Reply #2 on: May 05, 2014, 06:20:04 PM »
I vote on the GHQ!
De Hill
Re: engine running
« Reply #3 on: May 06, 2014, 06:14:58 AM »
They'll all be running including the GHQ.  I'll have them at Brobak's.  And Dan B. will have his GHQ, too.
Offline Hoss Cain
Re: engine running
« Reply #4 on: May 06, 2014, 01:55:23 PM »
Theys shore 'nuff be PURTY!  #^
Horrace Cain
AMA L-93 CD and Leader
Offline dennis lipsett
Re: engine running
« Reply #5 on: May 06, 2014, 04:41:58 PM »
I ran the G Mark 5 cylinder radial. Prepped it to start for the first time said that it was doubtful that it would hand start. It started on the first flip. Hand started it for the rest of the time that I had it. Got rid of it as it had the power of a worn out 09 engine. It is a .30 displacement engine.They went up in price for the collectors and I guess they are about the only ones that would still want them.
Re: engine running
« Reply #6 on: May 06, 2014, 06:22:02 PM »
Bill, you need to send that Saito twin to me!!! #^
Re: engine running
« Reply #7 on: May 06, 2014, 06:32:13 PM »
Here is my Saito 90T twin on my 76" Lazy Ace. It fly,s it pretty well beings it weighs 14 pounds. Flat bottom wings and stab do wonders for low power.
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Re: engine running
« Reply #8 on: May 06, 2014, 08:09:01 PM »
Well, next time your wife says not to run engines in the drive way show here this.....  it could be worse
http://bangshift.com/bangshiftxl/guy-raised-bar-pissing-neighbors-expert-level-five-radial-engines/
Dave Siegler
NE9N extra class
AMA 720731
Re: engine running
« Reply #9 on: May 07, 2014, 07:06:00 AM »
Man am I jealous of that guy.  The guy perched up on the bank looks like potential chopped liver!  Here's one you don't see running too often:
Re: engine running
« Reply #10 on: May 07, 2014, 07:33:01 AM »
Did you see the big spark and flash as he connected  the battery to the last motor,BOOM ~^
Re: engine running
« Reply #11 on: May 07, 2014, 09:13:51 AM »
Did anybody notice the railroad tracks in the back ground?  If a coal train came through it would drown out those radials.  One summer I helped remodel a house nest to a railroad track.   Even after the train engine passes there is still a lot of noise and then the tail engine come rumbling through.
Re: engine running
« Reply #12 on: May 07, 2014, 10:09:52 AM »
It looks like they are running on propane?  What else could be in those white tanks?  An interesting thought.  It also looks like his props are "clubs" used for bench testing.  They make just enough wind to keep the engine cool, but not enough to cause instability of his mounts (which do not appear to be very well anchored).
  • sport flier
Re: engine running
« Reply #13 on: May 07, 2014, 05:29:57 PM »
Are the tanks compressed air starters?
Dave Siegler
NE9N extra class
AMA 720731
Re: engine running
« Reply #14 on: May 09, 2014, 12:45:00 PM »
This is what was left after I cleaned things up.
Offline George
  • Love people, Use things.
Re: engine running
« Reply #15 on: May 09, 2014, 03:00:37 PM »
Bill, did you set the timing on the GHQ to run CCW?
George
George Bain
AMA 23454
Offline George
Re: engine running
« Reply #16 on: May 09, 2014, 03:03:09 PM »
Last time I saw a long nose Fox .59 run was in the late fifties. I remember it being LOUD!
George
George Bain
AMA 23454
Offline Hoss Cain
Re: engine running
« Reply #17 on: May 10, 2014, 09:30:57 AM »
Way back in days gone - around 1965 +/- - I had a fair engine collection, mostly sparkers. I had fun with a GHQ. I finally cut a 1 X 6 board about 12" long. Set up 4 wheels to spin freely under the board. Mounted an engine mt. to accommodate a 12" prop and ignition/fuel stuff. That engine started well but I could NOT get it to run adequately to pull its own weight. I even tried it with a glow plug and the ignition stuff off the platform. Finally got down to a 9-6 prop and some extra thrust by sound (NO TACHS back then that I knew about )  but the setup would NOT pull its weight.  I have heard that some of the old-timer FF folks have used the GHQ with success.
I did successfully fly a CL model with a Thor 29(30) on spark and glow.
So  have you had any trys with your GHQ?
Horrace Cain
Re: engine running
« Reply #18 on: May 10, 2014, 12:37:36 PM »
The 59 is STILL very loud!  I run MY GHQ CCW no problem, the timer will turn 360 deg.  Using 2:1 gas oil, mine turns a 13 x 5 Master Airscrew maybe 4500-5000 rpm;   it would definitely move its own weight!  It has the stamped piston and fair to moderate compression.
« Last Edit: May 11, 2014, 07:58:42 AM by Bill Mohrbacher »
  • sport flier
Re: engine running
« Reply #19 on: May 10, 2014, 08:34:38 PM »
Bill, your engine stands look interesting do you have any photos of the stands?
Dave Siegler
NE9N extra class
AMA 720731
Re: engine running
« Reply #20 on: May 11, 2014, 07:04:25 AM »
Base is Harbour freight, stands are 1/4" aircraft plywood
Re: engine running
« Reply #21 on: May 11, 2014, 07:05:55 AM »
more pics
Offline George
Re: engine running
« Reply #22 on: May 11, 2014, 09:54:16 AM »
more pics
Is that a REAL Mills .75?
I only have replicas. :-(
George
George Bain
AMA 23454
Re: engine running
« Reply #23 on: May 11, 2014, 05:07:16 PM »
Yes, it is a real Mills
