So Jamie, that must be a sign that you are close to ready with the Ring Master?
I have drilled some props like Garf has and always worried about all those cut in 2 fibers(grain) in the hub area of the prop.
That was the reason for counter boring face of prop to the Dia and thickness of the prop washer. Much stronger than the boring out the guts.
When drill one for the prop adapter would be wise to not use it on anything more powerful than an older .35 stunt type engine.
Sometimes guilty of not following my own advice.......
Garf, might want to cut the rear of that adapter off or the prop might be free to slip!
David
Breaking props the old fashion way
