  • June 25, 2025, 04:31:57 PM
Author Topic: Cox International glow plugs  (Read 1150 times)
Offline bill bischoff
« on: September 05, 2022, 06:30:04 PM »
 I noticed on the Cox International web site, they sell a regular 1/4-32 thread long reach glow plug to go with their conversion head for .049 engines. It looks to be a perfectly normal plug, listed as hot heat range. For $4.95, this seems like a decent deal these days. Has anyone tried them in larger engines?
« Last Edit: September 08, 2022, 05:46:47 PM by bill bischoff »
Offline Reptoid
Re: Cox International glow plugs
« Reply #1 on: September 06, 2022, 12:50:29 PM »
Looking closely at the photo; I'm guessing that's a Fireball (Swanson) Glow Plug.
Like this: https://brodak.com/engines/glow-plugs/fireball-standard-long-glow-plug-1-5v-to-2v-1.html
       Don
       AMA # 3882
Offline Dwayne Donnelly
« Reply #2 on: September 06, 2022, 01:31:24 PM »
I think you're right, $4.95 is good so it's a good question, can you run these in bigger engines?
Offline Lyle Spiegel
« Reply #3 on: September 07, 2022, 06:50:38 AM »
is the subject plug a long or short?
Lyle Spiegel AMA 19775
« Reply #4 on: September 08, 2022, 04:03:22 PM »
Hopefully Swanson has fixed their problems from years ago.  Either the filament would blow, like a fuse, or the plug would leak around the post or could even blow the centerpost out if it was run on powerful engine.
If they've gotten problems sound $4.95 is a dynamite price.  They were pretty close on the heat range.  It was fairly easy to see when you spotted the ring and it was either green, yellow or red (I think).
Offline Peter in Fairfax, VA
« Reply #5 on: September 08, 2022, 06:58:25 PM »
Epoxy over the Fireball seal was popular.
