Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 18, 2025, 10:47:09 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Engine choice for Encore 40
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Engine choice for Encore 40 (Read 1311 times)
Michael Schmitt
AMA Member
Trade Count:
0
Ensign
on:
February 24, 2010, 10:15:48 AM »
Hi Guys
I'm building a Encore 40 with a sheeted foam wing and Im trying to figure out which engine to go with. A PA 40 ultra light or a LA46. My prior Encore 40 had had a LA46 in them and have worked well for me. This foam wing may finish heaver because it will be entirely painted instead of ultra coat and painted fuse.
I guess the short question is which engine will have more power
thanks
Logged
Zuriel Armstrong
Trade Count:
0
Captain
Re: Engine choice for Encore 40
Reply #1 on:
February 24, 2010, 02:01:52 PM »
Howdy Michael,
I think either engine would work great. It really depends on how clean you want the nose. Rear exhaust or side.
Logged
Zuriel Armstrong
AMA 20932
James Mills
AMA Member and supporter
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Reply #2 on:
February 24, 2010, 05:51:22 PM »
Mike,
I'd lean toward the PA 40 lite, I was impressed with how well Charlie Reeves ran in his Super Ares last year at the Nats (and I think Jim Lynch ran one in his the year before as well). May even weigh less than the OS.
James
Logged
AMA 491167
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Reply #3 on:
February 24, 2010, 10:17:13 PM »
If $$ no object - PA 40 UL hands down. As an alternative to the OS 46 consider the Enya 40 XZS. A real jewel of an engine and no back plate or needle valve change needed.
Logged
Pete Cunha
Sacramento CA.
AMA 57499
Dennis Vander Kuur
Trade Count:
0
Commander
Reply #4 on:
February 25, 2010, 10:53:42 AM »
The cost of the engines or other suitable engines are not really an issue because Mike already has several LA .46 engines and just acquired the PA engine. The real issue is that his ENCORE 40 fuselage is already partially built and is setup for an LA .46 using a muffler. So to use the PA .40 Ultralight Mike will need to redo the mounting hole setup and also increase the fuselage depth to accommodate the tuned pipe for the rear exhaust PA .40.
DennisV
Logged
Dennis L. Vander Kuur
AMA 29292
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Reply #5 on:
February 25, 2010, 03:11:40 PM »
Ahh, that puts a whole different spin on the question. It's easy - go with the LA 46 . Be comfortable with the fact that bang for the stunt-buck it is probably the best deal going. Plenty of power for a plane that size and a very consistent runner.
If you still want to run the PA-40 and the fuselage is not attached to the wing yet, I would just build another fuselage and re-design the front end for the RE configuration. You can always use the .46 fuselage for another project. IMHO this will give better results than modifying an existing fuselage.
Logged
Pete Cunha
Sacramento CA.
AMA 57499
Michael Schmitt
AMA Member
Trade Count:
0
Ensign
Reply #6 on:
February 26, 2010, 11:42:54 AM »
Hi Guys
The decision has been made and the PA 40 ultra lite engine fitted into the fuselage
Thanks for you help
Logged
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Reply #7 on:
February 26, 2010, 12:05:42 PM »
Not too shabby!
Logged
Pete Cunha
Sacramento CA.
AMA 57499
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
