I am posting this for Sleepy. Clancy
TRILOGY is a triplane designed for stunt, no not for expert or advanced but for beginner and intermediate. As pictured it has not been flown. I waited until construction was finished for photos so as not to use up too much band width. I like to take all the pictures before the first flight. I’m not a good pilot. I will post how, when and if TRILOGY flies. Wing area is 897 sq in. Didn’t make target weight of 66 ounces, it weighs 72 ounces. Engine was a bargain OS Max SF 61 at 24 ounces with extra head gasket and muffler. This is the best reason to use a short, short nose design. Airfoil is flat back 16.4 percent thick with high point at 24 percent and uses a stock SIG leading edge.. The top view perspective makes stab look larger. The TVC is 4.6. One photo shows the alignment sticks clamped in place to align wings, quite a chore. The main wing struts are 3/8” dowel with auxiliary struts ¼” dowel. The head on shot shows the vertical wing spacing of 8” measured at airfoil centerline. May look a bit odd, but large vertical wing separation makes wings more efficient. There is no wing stagger. As shown, I make my own elevator control horn as well as bellcrank. Both are strength tested as mounted. The 6 ounce tank is mounted inboard of the engine (short nose again). I used Monocote for the first time in 40 years. I’ll now go back to silkspan and tissue. This is the first plane I have built when not using wing and stab foam construction since my FF days in the mid 1970s. It has been a fun project, SLEEPY.
