Haven't flown CL since mid 90s, and then only 1/2A.
Want to build Flite Streak, then Fancherized Twister, but short on time these days so picked up a used Brodak Pathfinder w/OS 35 FP just to get flying ASAP.
In prepping for first flight I used epoxy to seal up some delamination cracks between ply, hardwood and balsa forward of wing in engine mounting area, built up some crushed wood under the engine mounting lug beds w/ epoxy-glass, glassed a cracked rudder, freed a binding pushrod, and other minor issues.
As a novice, and never having flown this model, one area of concern are the angles of the elevators and flaps.
It was set up with the forward (bell crank) pushrod in the top hole in the flap horn (fifth of five holes from the flap), with the rear pushrod in the next hole down (4th of 5). This initially gave 21* (degrees) of down, on both elevators and flaps, and 14.5* of up, which seemed unbalanced to me.
Adjusting the fork on the aft end of the fwd rod out 6 turns equalized the up and down angles at 17.5*.
But then I wondered if this was enough overall angle, so I tried the fwd rod in the 3rd hole on the flap horn. But this gave angles of 21* down and 26.5* up.
My questions are:
1) How much angle should there be on average?
2) Should the available angle be biased up or down, or just equal?
Any comments or advice appreciated. I'm excited about putting up a flight soon!
