  • June 25, 2025, 01:09:17 PM
Author Topic: Monokote tip / Trick  (Read 1657 times)
Online Paul Taylor
« on: June 18, 2023, 06:49:04 PM »
This might be old news for some. Louis Rankin taught me this.
Get some modeling clay and roll a coil along the edge of the monokote next to the joint. It acts as a heat sink. The clay will liquidate a little but the monokote does not curl up. Just be sure to iron the edge down first.
Re: Monokote tip / Trick
« Reply #1 on: June 18, 2023, 08:30:18 PM »
I’m confused. What’s the purpose of this??
« Reply #2 on: June 18, 2023, 11:37:42 PM »
To use up the clay around the house so that the kids aren't smearing it on the walls?
The Divot
Online Paul Taylor
« Reply #3 on: June 19, 2023, 07:08:57 AM »
Acts as a heat shield to keep the monokote from curling up at the edge.
Offline Phil Spillman
« Reply #4 on: June 19, 2023, 09:43:57 AM »
Thanks Paul, I'll give it a try on my soon to be performed repair! Missed you at the Brodak FlyIn. We had a great time for the first three days. Couldn't afford to stay the entire week this time!
Phil Spillman
Phil Spillman
Offline Rusty
« Reply #5 on: June 19, 2023, 11:22:15 AM »
Don't you have some extending over the edge so you can iron it down?  I usually have about 1/2" ironed on the edge and seal that so fuel doesn't get under it.
Online Paul Taylor
« Reply #6 on: June 19, 2023, 02:03:32 PM »
Phil Spillman
Hey Phil
I really wished I could have made it up. It’s a two day drive for me now that we moved farther south. I miss seeing all the gang. I hope it happens next year. 😉
Online Paul Taylor
« Reply #7 on: June 19, 2023, 02:06:12 PM »
This is right against the fuselage. Iron it down with a trim iron, lay the clay down and hit it with the heat gun. The covering will not roll up if you get too much heat next to the fuselage.
« Reply #8 on: June 19, 2023, 04:19:34 PM »
Great Idea.  I will try it.  Nothing can compare to the overwhelming sense of doom as you watch one of the edges come loose and curl up before you can move the gun.  I monokote my fuselages as well and I do the fillets separately first with about a 1/2" overlap on both the wing and fuselage.  I sand the edges then go for the wing.  If you don't get the edges sealed really well before going to the gun you are going to have a mess.
Online Perry Rose
« Reply #9 on: June 20, 2023, 07:15:05 AM »
Wing to fuselage joint, apply the monokote 1/8 from the fuselage then put the fillet over the monokote and paint the fillet.
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #10 on: June 20, 2023, 08:02:34 AM »
i use a wood ( usually 1/32 plywood) piece to protect the 1/2" lip of the monokote ( ironed with the trim iron, very hot) close to the fuselage. This makes the heat flow towards the tip and let the glued edge undisturbed.
then i apply white primer over the covering, sand, and overlap with the final color about 1/2 over the ironed edge.
