  • July 14, 2025, 11:43:43 PM
Author Topic: Electric Twister comes in when turning and Timer set up???  (Read 12981 times)
« on: June 13, 2022, 10:22:35 AM »
Hey Guys, need a little help.
I built a Electric Twister and in the process of setting it up.
Setup is a Hubin Timer, BA ESC, Cobra motor.
I had to change the program on the timer to Throttle mode because it would not allow me to adjust the RPM. Is that the correct selection?
The plane flys good in level flight and when the motor quits it glides in with little handle input.
When in flight I turned it over to inverted flight and it seem to come in and get light on the lines. Then when turning it back over to up right flight it really came in and went into free flight.
What are some things to check?
Offline gene poremba
Re: Electric Twister comes in when turning and Timer set up???
« Reply #1 on: June 13, 2022, 10:39:50 AM »
 Paul, I'd look to see that one side of your elevator and or your flaps are not tweaked more than the other side. Look at the model from the tail end at a slight distance and eyeball the elevators and flaps to see that they are on the same plane. You should be able to see any warp in the wings also......Gene
« Reply #2 on: June 13, 2022, 10:40:15 AM »
  Check for a warp, and whether or not the wings are level upright and inverted. Even if you don't find a warp, adjust it until the line tension is equal upright and inverted. I presume that the hinge line is already sealed, if not, seal the hinge lines and start over.
   Other possibilities include stab tilt.
« Reply #3 on: June 13, 2022, 11:39:25 AM »
I need to make a video on how to do this...
Put the spinner on your toe, close one eye, and sight down the fuselage.  Tilt the plane in pitch until you see equal amounts of wing above and below the trailing edge (move the flaps as necessary so you can see).
Now, without moving the position of the plane or your head, slide your line of sight to each wing tip.  You should see equal amounts of wing above and below the trailing edge.  If you don't the wing is twisted and you need to fix it.
While you're doing that, check to see whether or not the flaps are lined up with each other.  If they aren't, and the wings are straight, then the flaps need to be tweaked (after you fly it, the flaps should be tweaked to where they need to be, but more than a 1/4" difference between them and the plane flying pretty good means that something is warped).
Now tilt the plane in pitch until the vertical stab is visually just touching the wing.  On a Twister, the bottom of the stab should look exactly parallel to the wing (on a wing with taper, the stab should be spaced equally at the tips).  If there's visible stab tilt, you need to fix it.  While you're looking, make sure the elevators are lined up with each other -- if they're tweaked, you want to un-tweak them.
Finally, measure the length of each stab from the fuse center to the tip, to make sure you centered the stab.  These should be equal to within 1/16".  If you did, measure each rear tip of the stab to the back of the canopy at the center of the fuselage.  These should be equal to within 1/16".
If anything looks wrong report back -- we'll tell you how to fix it.
« Reply #4 on: June 13, 2022, 11:48:56 AM »
On the timer, I have never used a BA ESC, however, I do not think that Throttle mode is correct.  When the motor looses RPMs in any kind of maneuver it should recover immediately.  You should be feeling an RPM "bump" coming out of something as simple as flipping the plane over.  Anything else you do to correct this will be a waste of time until you get the timer/esc right.
Back to aerodynamic reasons for the problem other that what Brett, and now Tim, posted which will be the primary cause.  One I have encountered was a weak flap horn being driven by a bolt on horn on the outboard wing.  All of the control force went to the outboard flap and they did not move equally under load.  Same would apply to the Elevator.  Next comes tip weight.  I flew an F-Twister as my Profile in competition and practice plane off season for two years.  It needs enough tip weight.  Mine also liked being a bit nose heavy.   Here is where I get slapped upside the head by the no rudder crowd.  Mine never flew very well over 45 until I gave it 1/4" of rudder offset.  Maybe it was trying to hold on to it's roots LL~
Oh, one more.  Take a look at the line rake.  If it is excessive, you may be flying nose in already.
Offline Bob Hudak
« Reply #5 on: June 13, 2022, 12:58:04 PM »
Need to know if you're running a pusher prop. If you are then the motor needs to be mounted with up and out thrust. About 1/16" outthrust and one washer to give it upthrust.
 After looking at your pic it appears to be standard rotation, make sure you have a bit of down and out thrust if this is so.
350838
Online Howard Rush
« Reply #6 on: June 13, 2022, 01:08:07 PM »
Tim's process explanation is good.  You can alternatively put the plane on a table and prop up the tail until you can center the TE on the wing from your eyeball reference.  Follow Tim's process and tape the flaps before you fly it again.  Then put a good size blob of clay on the right wing tip and go to the beginning of the Walker trim chart.
Our club once put on a stunt plane trimming clinic.  I'd to the Tim process, then Paul Walker would do the flight trimming.  He was tired at the end of the day.
« Reply #7 on: June 13, 2022, 01:09:27 PM »
Thanks everyone for the quick replies. I will check all of the above and report back. Will try and get some detail pictures.
Stay tuned….
Online Howard Rush
« Reply #8 on: June 13, 2022, 01:16:39 PM »
Stay tuned….
Good luck picking out the good advice from the bogus.
« Reply #9 on: June 13, 2022, 01:58:53 PM »
... You can alternatively put the plane on a table and prop up the tail until you can center the TE on the wing from your eyeball reference....
In my shop it's much easier to find an unoccupied toe than a few square feet of unoccupied table top.  But yes.
Online Howard Rush
« Reply #10 on: June 13, 2022, 02:29:26 PM »
My airplane is so heavy that the toe method is painful-- another reason why I don't use a needle-nose spinner.
« Reply #11 on: June 13, 2022, 03:00:09 PM »
If it turns in that bad it must be a glaring problem.
On my Ftwister I had to replace the wood for the flaps because it was too punky. Since it's already built, you could strip off the covering and glue 1.6oz glass on the bias with zap zpoxy top and bottom.
How thick are your joiner wires? should be 3/32" min.
« Reply #12 on: June 13, 2022, 09:53:17 PM »
I had a few minutes before bed and looked at the alignment. It was hard to see it on my toe so I put it on a rack. I still did not see anything. So I thought I would take a picture. Maybe I see it. What do y’all see?
« Reply #13 on: June 13, 2022, 09:58:46 PM »
Well it won’t let me attach the photo.  😖
« Reply #14 on: June 13, 2022, 10:06:08 PM »
Try this
« Reply #15 on: June 13, 2022, 10:08:42 PM »
I will measure the stab tips tomorrow and report back.
« Reply #16 on: June 13, 2022, 10:59:06 PM »
Try this
It looks close enough for a profile. It will twist in flight anyway.  It is not enough to be the root cause.  My money is still on a weak inboard flap.  What is with the bellcrank pushrod?  It looks pretty thin.
« Reply #17 on: June 14, 2022, 06:53:50 AM »
Thanks Ken I will check the flaps. The outboard stab is up. The compressed photo does not show it very well. I will try and get a better photo.
As for the pushrod, again it’s a bad photo. The pushrod is a arrow shaft. 😉
Offline Jim Svitko
« Reply #18 on: June 14, 2022, 08:52:44 AM »
Regarding the bellcrank to flap pushrod:   Ken might have spotted something.  Is that a "Z" bend I see in that pushrod?  Although that section of pushrod is rather short, you are putting an off-center load on that section of wire.  The pushrod might be buckling just enough to cause a problem since the load is not aligned with the axis of the pushrod.
« Reply #19 on: June 14, 2022, 09:08:16 AM »
Try this
The wing looks straight.  The stab looks like it's installed fairly well, but the stab itself looks warped, and in a direction that would make the plane roll to the inside when you're inverted.
You may be able to twist the stab straight with heat -- I'd try that first.  Expect that you'll have to keep at it.  The stab that came in the Twister kit that I built was heavy 3/16" wood of no particular distinction, and pretty close to A-grain (i.e. plain sawn).  If that's what you got in your kit, then it will just naturally want to warp.
If you can't get it to stay flat then start a new thread about just that subject -- you'll get about a bazillion suggestions for what to do about it, so you can pick and choose the one that most suits your fancy.  Most will involve replacing the stab, so be warned.
« Reply #20 on: June 14, 2022, 09:43:30 AM »
I apologize, I buried the lede - since it gets light in either turn, *add tipweight* until you can reliably get through both turns, THEN, check the difference between the upright and inverted roll angle. It is no accident that the first block in Paul's flowchart is "tipweight" - in this case, you have to keep it alive long enough to get to a reasonable test. Then, start checking for what is warped.
p.s.
« Last Edit: June 14, 2022, 10:12:58 AM by Brett Buck »
« Reply #21 on: June 14, 2022, 09:50:05 AM »
I apologize, I buried the lede - since it gets light in either turn,...
I re-read Paul's description, and I still got that it gets light on outsides only (inverted and the outside half-loop to upright).
So, Paul -- does it only get light in inverted flight and when you're doing that outside half-loop to upright?  Or is it just light all around, or light when you turn in either direction, or what?
I'm not questioning Brett -- he is correct that more tip weight will keep the airplane alive long enough to figure out what's really going on.  If you fly again, add tip weight -- then you fix your warp, yaw, whatever, and you'll take it out again.
« Reply #22 on: June 14, 2022, 10:26:33 AM »
The flaps are attached using the monokote method so it is sealed.
And I do have some tilt in the stab. The OB is up just a tad.
« Reply #23 on: June 14, 2022, 10:30:34 AM »
  Note my addendum - if it is getting light in both directions, *add tipweight* until it is safe to fly, then, proceed with evening out the roll angle.  I apologize for missing the important bit on my first response.
« Reply #24 on: June 14, 2022, 10:30:58 AM »
It has 1/4 oz tip weight. I added 3/4 oz and will check next time I’m out.
Might try and get the OB stab down a tad.
Guys I really appreciate all the input. It’s been awhile and I dusting off the brain cells.
Going searching for that trim chart. 🥴
« Reply #25 on: June 14, 2022, 10:31:51 AM »
Thanks👍🏼😎
« Reply #27 on: June 14, 2022, 11:41:16 AM »
 LL~
« Reply #28 on: June 14, 2022, 06:54:56 PM »
http://flyinglines.org/pw.trimflow1.html
   This needs to be pinned at the "At The Handle" section or someplace easy to find. It gets referred t a lot, so shouldn't it be on the forum!!??
« Reply #29 on: June 14, 2022, 07:07:27 PM »
  In this case, the first thing is on the chart is to  "get the wings level* which is directly on point, because I can almost positively guarantee that they AREN'T right now, both rolled in all the time, and also not the same upright and inverted. There may be *additional* problems, but until you do that, you cannot address the others.
   Note that this also sounds like a hallmark example of "Twister Disease", where the excessive rudder offset can make the wings normally level even without enough tipweight, which will then show up in corners. Looking at the posted picture, it appears to have something like 1/2"-3/4" of rudder offset, which will generally cause nose-out sideslip and outboard roll (masking inadequate tip weight) until you start to maneuver, then it yaws closer to tangent, removing the sideslip and rolling the airplane inboard in either direction.
   But you don't dare do anything about that without adding adequate tip weight and getting the upright and inverted roll angle to match. If you just remove the rudder offset right now, it may not even safely fly level.
« Reply #30 on: June 14, 2022, 07:47:20 PM »
Will give it a closer look. Thanks
« Reply #31 on: June 14, 2022, 08:15:05 PM »
Ok. More photos.
I don’t have rudder offset, flaps seem solid and firm. I don’t have any Z bends and pushrod is a arrow shaft.
I looked down the wing and it looks straighter then the lumber at Lowes. 🤣
I will try and cut the stab and level it out. And check for warp.
Question - with the OB stab being a tad up would it not cause the plane to roll out?
Again thanks for all the help.
Offline Dan Berry
« Reply #32 on: June 14, 2022, 08:38:44 PM »
Stab parallel to the wing is REAL important.  If the inboard stab tip is high , down elevator will roll it toward you.
To get it levelled you can slice the fuselage under the stab and cram some 1/64 ply (or less) into the cut and wick some thin Cya into it.
« Reply #33 on: June 14, 2022, 08:41:23 PM »
It's hard to tell over the internet but, looks like the inboard wing is twisted up a little in that picture.
« Reply #34 on: June 14, 2022, 09:22:39 PM »
WHOA!  Slow down!  This is why I suggested you start another thread -- I'm going to give some direction, and then this thread is going to get totally sidetracked in "how to unbend a bent airplane".
You don't need to cut the stab out unless it is either hopelessly warped or hopelessly tilted.
"Hopelessly" meaning that you've tried straightening it using heat, and definitely failed.
I've straightened tilted stabs on profiles where one tip was as much as 1/4" higher than the other, by getting the fuselage good and warm ("warm" is like hot, only the 'coat or paint isn't melting yet -- "I can still hold it without yelling" isn't warm enough), then twisting it in the opposite direction about as much as the original twist, then holding it there until everything cools down.  It takes a long time, because you want the heat to penetrate into the wood, and if you've fiberglassed the fuselage you want whatever resin you used in the 'glass to soften a bit.  So you need to warm it up slowly, get it good and warm (really, the hotter the better, unless things are melting off the plane, turning brown, bubbling, or catching on fire).
It can be done.
I'd try that first, because it's much less invasive (unless you scorch the paint -- big bubbly brown marks counts as "invasive").  If you just can't get it to work (which has also happened to me), then take Mr. Berry's advise and cut & wedge.  (And, if you cut & wedge and miss by a hair, you can probably bring it the rest of the way with heat).
Note that sometimes they'll settle back in the direction of the warp or tilt -- just keep at it.  Usually if I can get it to move at all, repeated treatments will eventually see it settling down where I want it to be.
Ditto any warp in the tail feathers.  For it to work you probably need the heat to extend into the wood, and if the wood is cupped then you'll probably have a fight on your hands -- I'd aim for the left and right tips to be level with the stab root, and just close my eyes to any cupping of the wood unless I wanted to rip the stab off and build a new one.
« Reply #35 on: June 16, 2022, 07:43:30 PM »
It looks to me from the very first picture that the tip of the outboard flap is not on centerline of the wing TE. I've seen this on a few planes, and didn't expect it would be a good thing. Basically, the hinge slot was not centered in the wing TE or flap LE.  I have some doubts about hinge seals fixing that, but could easily be wrong, and I don't know what an easy solution would be, other than refraining from doing that on the next plane. Somebody will be along shortly to tell me I've got it all wrong, but I won't name names.  y1 Steve
« Reply #36 on: June 16, 2022, 08:04:27 PM »
You're always wrong, Steve, that's why we like you so much.
Good catch -- I looked again, and I'm not seeing it.
I think you're right in that it it's not a good thing.  It'll probably cause similar oddities to fixing a warped wing with a fixed roll tab.
This is guessing, but I'm guessing that if you get the plane visibly un-warped, then you ought to iron out the remaining roll tendencies caused by that hingeline anomaly by tweaking the flaps.  Then you can either leave the flaps tweaked, or the next time that you de-warp the wing (which you will do, it's just how the wing is built) you can leave in a mild warp that'll let you de-tweak the flaps.
Certainly, if you're flying in Intermediate, getting that far with the plane will make it better than you, and you can concentrate on flying.
« Reply #37 on: June 16, 2022, 08:52:42 PM »
I think that is an optical illusion.  I think the flap is a tad shorter than the wing BUT, now that my focus got put on that flap, it appears to be down some.  Ok, flaps go down but when they do the elevator goes up but the one in the picture is perfectly flat.
Go fly it.  See if any of this rambling is making things better.
I just has to play some more.  I loaded that 1st pix into a viewer and Steve wins - it is not centered.
« Reply #38 on: June 17, 2022, 07:03:38 AM »
Thanks guys for all the input. With all this brain power we will get this fix! 😂
Update: @Tim - I took a little heat and push the stab down a tad. ✅
@Steve - the flaps are straight and sealed to tight. The hinges are monokote, all the way. ✅
I added tip weight so I will try and get out to the field soon.
I have to stay home for about 8 days. I was exposed to Covid a few days ago. Hope we don’t catch it. 😖
« Reply #39 on: June 17, 2022, 07:32:53 AM »
     Do as you wish, of course, but I don't think there is any requirement to quarantine yourself unless you have symptoms - that's the case even here in New East Berlin (AKA Santa Clara County). You can also get free rapid antigen tests and know in about 1/2 hour.
« Reply #40 on: June 17, 2022, 08:10:28 AM »
I don't know what the current guidance is, but when things first eased off you were fine as long as any two of these three applied: outside, masked, vaccinated.
You can probably add "stuck a swab up your nose and only had one stripe appear" to that list.
« Reply #41 on: June 17, 2022, 09:59:02 AM »
I’m in Florida and our future President has lifted all restrictions.
I’m fully vax’ed as I trust my personal doctor’s advice. I just don’t want to pass this on if I’m infected.
But my biggest concern is my daughter in law and my future grandson. 😎
I want to shield the family and friends.
I personally know people that died from Covid. 🥺
« Last Edit: June 17, 2022, 10:29:02 AM by Paul Taylor »
Offline Doug Moisuk
« Reply #42 on: June 17, 2022, 10:16:32 AM »
Is this what your looking for?
Doug Moisuk
MAAC 3360L
« Reply #43 on: June 17, 2022, 10:24:40 AM »
    Paull just posted that in the last day or so in the Stunt Design section and has it pinned to the top of the section.
   THANKS PAUL!!
« Reply #44 on: June 17, 2022, 10:27:20 AM »
Thanks!
Yea I found it doing a search. Now it’s pinned where I had access. 😎
« Reply #45 on: June 17, 2022, 10:27:48 AM »
   THANKS PAUL!!
Offline Doug Moisuk
« Reply #46 on: June 17, 2022, 10:41:49 AM »
This is the simpler version.
Doug Moisuk
MAAC 3360L
Offline MikeyPratt
« Reply #47 on: June 17, 2022, 07:38:10 PM »
Hi Guy’s,
What gets me is why wasn’t the surfaces checked be for test flights began?  Every Twister or Banshee I’ve ever know or seen needed at least an 3/4 ounce of tip weight, so three flats of SIg weights, 2 tenths for the tip weight box = almost 1 ounce of tip weight.  A preflight of the bench trimming process should be done before test flying the model, Period!
1) Triple check each control surface to make sure they are not warped or out of alignment
2) Make sure the stab & elevator are properly aligned
3) hook up the controls as shown on the plan, you can always make changes later, make sure you have equal control throw and adjust to get it there.
4) Seal the hinge lines flap &elevator before flying
5) Set rudder off set a small amount, what’s show on the plans is too much, at most start with 3/32”.
6) Set the CG as close as you can to the location shown on the plans, or slightly more CG forward, again you can change it later if needed.
7) Line length start at 60’ C to C.
8) The lap times should be somewhere between 5.1 to 5.5
You want to give yourself every advantage for successful first flights, set lap times after a few flights once your satisfied it’s flying good without ant weird things happening.  Now more unto Paul’s flow chard to fine tune it from that point.
Later,
Mikey
« Reply #48 on: June 17, 2022, 08:54:52 PM »
Hi Guy’s,
Why would you assume I did not check and recheck before I put the finish on a plane? I Did a bench trim too.
I know people have built some beautiful stunters and discovered a misalignment after a few flights.  Billy W. being one. It’s recorded on one of Bob Hunt tapes.
If you read the entire thread the misalignment was not much on the stab and not much was need to drop it 1/8 of a inch.
Most people here are quick to help and slow to judge.
Good day Sir.
« Reply #49 on: June 17, 2022, 09:36:27 PM »
I cut 1/8
I don't know why I didn't mention that as soon as I saw the 1/4oz post.  On my fancherized one I extended the wing one half rib on each side and made my outboard flap 1/8" larger, actually I cut 1/8 off of the inboard.  I ended up with 1 1/2 oz. tip weight.  The unequal flaps let you carry a bit more.  The tip weight is one thing that will have the same symptoms upright as inverted.  I don't know why I missed that.  Brett touched on it. My first plane when I came back after 30+ years in the wilderness was an ARF Nobler.  I got it in the mail 2 days before our club's 1st contest of the year and literally threw it together so I could enter.  I got there late and didn't have time for a test flight.  It took off and did what yours did.  Totally unflyable.  My first flight and first official after coming back was a whopping 56.  Turned out that the factory forgot the tip weight.  I had zero.  That plane turned out to be an excellent flier.
