General control line discussion => Open Forum => Topic started by: Louis Keller, Jr. on December 13, 2013, 04:29:11 PM
What effect does primer color have on the finish?
light colors are more affected ... but the correct shade of primer is covered easier by color..
Depends on the final base color. Yellow is the worst, it needs a fully blocking primer or base coat. A solid white base works the best.
Medium density colors, reds, blues, greens, etc. can go over a white or light grey base. Depends on the exact color shade you are looking for.
Dark colors are less sensitive, but a darker primer may help reduce the amount of color coat needed.
The best bet is to make a test panel to try out the color scheme, especially if you haven't tried something similar before.
