  • July 20, 2025, 12:29:12 AM
Author Topic: effect of primer color on finish?  (Read 834 times)
Offline Louis Keller, Jr.
« on: December 13, 2013, 04:29:11 PM »
What effect does primer color have on the finish?
Offline 55chevr
Re: effect of primer color on finish?
« Reply #1 on: December 13, 2013, 04:46:53 PM »
light colors are more affected ... but the correct shade of primer is covered easier by color..
Joe Daly
« Reply #2 on: December 13, 2013, 05:06:36 PM »
Depends on the final base color.  Yellow is the worst, it needs a fully blocking primer or base coat.  A solid white base works the best.
Medium density colors, reds, blues, greens, etc. can go over a white or light grey base.  Depends on the exact color shade you are looking for.
Dark colors are less sensitive, but a darker primer may help reduce the amount of color coat needed.
The best bet is to make a test panel to try out the color scheme, especially if you haven't tried something similar before.
