Okay, here's a couple of pics of mu jig, since I'm working alone today this is the limit of help or I'd have my help take some "almost action" shots of coring the beast.
I do think that Doc and Willie have superior techniques since they clamp the wing and drop the hot rod through the wing instead of moving the wing up over the rod as I do. I'm just too darned lazy to modify my jig since this works fine for me.
I clamp it level, chose a line for the TE to follow, set the rod at the proper distance from the jig for the center of the wing, (held in the shuck at all times by the way,) and tighten the rod so it won't swivel. Then I heat the rod, start the wing up along the chosen guide line and take my time so the rod actually moves the foam out of the way by melting it rather than pushing through. The rod seldom if ever actually touches foan since it melts it away as it comes to it.
If you take your time, this works well. I still plan to some day switch to the other method of dropping the rod down through the wing as I think it's a more stable method with the wing clamped tight.
I hope these two pics help, feel free to grill me on it!
Blessings,
Will
