  • June 30, 2025, 03:17:41 PM
Author Topic: Tom Dixon Product Announcements  (Read 979 times)
Offline Jim Catevenis
« on: April 01, 2018, 05:19:47 PM »
Tom Dixon announces a couple of events-
(1)   Stalker .51 side exhaust engines are now (finally!) en route to the USA.  Most of the initial batch have been reserved, but a few remain unspoken for.  Also, Stalker can provide approximately 15 more immediately.  If you need a side exhaust engine for a Stiletto 660, Shark 45, or similar, consider one of these at $304.00 each.
(2)   Greenaway Patternmaster kits are available from Tom for $250.00. The kit includes pre-sheeted triple cored foam wing with plywood spars, and sheeted foam stab and elevators. Other balsa, plywood and hardwood parts are cut to shape from first quality wood.  A 3/32 inch aluminum landing gear is included, but you supply your favorite hardware.
The Patternmaster is Nostalgia and Super ‘70’s legal, as it first flew in 1978, and is perfect for the now available .75 to .82 size engines.  Bob Baron won the 1996 NATS with his Patternmaster and Super Tigre .60 power.  The Patternmaster was the basis of many of Windy Urtnowski’s planes including the Strega and .60+ size Cardinal.  Are you ready to be a “Pattern Master”?
(3)   Tom now has SIG SIGGP003 R/C long glow plugs available.  The plugs are $7.50 each or 10 plugs for $70.00 plus $3.00 postage
                                                     Contact Tom Dixon at 770 592-3279
        or
        315 Santa Anita Ave
        Woodstock GA 30189
