  • July 15, 2025, 09:19:06 AM
Author Topic: Early ST 51's to decide what year of manufacture.  (Read 1660 times)
Offline Allen Brickhaus
  • ACE
« on: June 18, 2013, 06:22:48 PM »
When were these produced?  The one with the slick side had the V and other lettering but it has been removed.
Re: Early ST 51's to decide what year of manufacture.
« Reply #1 on: June 18, 2013, 07:21:59 PM »
They go back to the late  1960s
  • ACE
« Reply #2 on: June 18, 2013, 08:04:28 PM »
Thank you,
Allen
« Reply #3 on: June 18, 2013, 08:18:04 PM »
They made  both ball bearing models and plain bushing models of the 51, Also the later ones had muffler lugs and thicker cylinder sleeves
Offline Brian Hampton
« Reply #4 on: June 18, 2013, 09:00:36 PM »
I have a test report from 1974 on what seems to be your engine at http://sceptreflight.net/Model%20Engine%20Tests/ST%2051%20%281974%29.html where it says the plain bearing version was from 1960.
« Reply #5 on: June 19, 2013, 12:13:05 AM »
These old plain bearing 51s are from around 1960 .
Piston / Liners same part No as Ball Race , which I think came out around 62 with the 56 , then the 60 around 1964 .
Was two ring & single ring , Two Ring being first series . Head chambers altered over the years , or Chantis too . :-\
« Reply #6 on: June 19, 2013, 12:25:15 AM »
« Reply #7 on: June 20, 2013, 01:43:06 AM »
More diatribe , from :http://sceptreflight.net/Model%20Engine%20Tests/ST%2051%20(1974).html
First Line says ' since its appearance in 1960 ! so may well be first made in 1960 . ! H^^
  • ACE
« Reply #8 on: June 20, 2013, 07:09:07 AM »
You have been a big help to me.  Thank you so much.
Allen
« Reply #9 on: June 22, 2013, 12:49:32 PM »
I like the reference to "contest R/C stunt" events.
Chris...
