If the results of Ty's "experiment" can generalized, and aren't due to some other factors, doesn't the long tail tend to exacerbate an inherent weakness of flapless planes: soft squares? Could a somewhat shorter tail with larger stab/elevator be preferable?
But there's a tradeoff to be made. The basic airplane is capable of turning tighter than you can practically control for competition stunt. So there's not much reason to make it any better than that. The longer tail will improve the acceleration in pitch and also the damping of the corners, so it starts and stops better and still give a sufficient corner.
Too long, and you are limiting it and the corners will get softer. The Skyray is sort of like that, at least my light version, it is clearly limited by it's tail moment, which I think is excessive for the wing loading. It's about perfect for the stock-weight model and a 20FP.
And I think you are overstating the "soft corners" from non-flapped airplanes. Stuff like the Ringmaster have to be flown soft because the airfoil is terrible, not because the tail moment or tail volume is inadequate. But reasonable-weight airplanes with good airfoils (Jamison Special, All-American, Doctor, and the Flite Streak) have *no problem* turning far tighter than you can consistently manage in competition.
