  • July 08, 2025, 05:43:51 PM
Author Topic: Dubro Hinge Size  (Read 676 times)
Dubro Hinge Size
« on: August 25, 2015, 10:45:55 PM »
I've got the regular Dubro pinned hinges on elevator and flaps of a 565 sq. in. plane and they are holding just fine. When do you need to go with the large Dubro hinges or can you just use more of the smaller ones?
Online Perry Rose
Re: Dubro Hinge Size
« Reply #1 on: August 26, 2015, 03:54:37 AM »
I use the medium size on everything. 3 on each elevator and 4 on each flap, never had a problem. I've seen models with 6 or more on each flap.
