  • July 19, 2025, 02:01:00 AM
Author Topic: Drying Racks  (Read 1987 times)
Mike Griffin
Drying Racks
« on: January 16, 2012, 02:53:35 PM »
Looking for some ways to hold components (ie.  flaps, stab, elevators etc) for them to dry after painting and before assembly.  Anyone have any pictures or descriptions or racks or holders you have made to do this?
Re: Drying Racks
« Reply #1 on: January 16, 2012, 03:11:07 PM »
I was recently faced with that dilemma, and solved it by bending some strips of tin can into right angles and screwing them onto a random board, spaced to fit into my hinge slots.  Then I threaded the elevator that I was painting onto the strips, and painted away.
Don't try this with a whole wing, but it should work for stabs, elevators & flaps.
Re: Drying Racks
« Reply #2 on: January 16, 2012, 03:12:28 PM »
Mike,
I use a piece of 3/4" particleboard, I make a slit in it lenghtwise on my table saw, almost all the way through, and then I use short sections of brass stock, about 1/32" thick, by 1/2" wide, and about an inch and a half long. I put the brass in the slit, and in the hinge pockets on the control surface. Then I wedge the brass into the table saw kerf with scrap balsa and a drop of CA to lock it in. I make separate pieces for each surface normally about two inches wide, that way I can spray Up onto the hinge face while painting.
Offline Paul Wood
Re: Drying Racks
« Reply #3 on: January 16, 2012, 04:18:39 PM »
Mike,
I use the Robart hinge points, so I just drill holes in a piece of plywood that matches the spacing of the hinge holes.  I then use a piece of coat hanger wire placed into each hole of the board to hold the painting surface up about 8" when inserted into the hinge hole.  I use a separate base board for each item to be painted.  I can move each assembly to and from the paint table and avoid overspray.  I would use the same method for flat type hinges, but use a piece of metal cut from something like a tin can instead of the coat hanger.
Offline Bootlegger
Re: Drying Racks
« Reply #4 on: January 16, 2012, 04:24:12 PM »
  Mike you might use 1/32" ply wood as "tabs" to hold the piece to paint it. Cut slots in some scrape balsa as a holder. Seems that I have read that this works.
 Keep us posted... :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Drying Racks
« Reply #5 on: January 16, 2012, 04:52:10 PM »
I use a corrogated carboard box and wooden meat skewers - you put the blunt end of the skewer into the flap/elevator horn hole or the slots for hinges in the stab etc - then poke the shap end into the box - you could also use foam - but the weight of the box usually stops it tipping over
Offline Allan Perret
  • Proverbs
Re: Drying Racks
« Reply #6 on: January 16, 2012, 05:29:57 PM »
Hey Mike:
Check out this post I did on this subject back in 2010 when I was finishing the RMD-3.  I have used them on 2 more planes since then, they work great.
http://stunthanger.com/smf/index.php?topic=18607.0
Allan Perret
AMA 302406
Slidell, Louisiana
Offline keith varley
Re: Drying Racks
« Reply #7 on: January 16, 2012, 05:30:23 PM »
I have used tabs of melamine (arborite counter top material) for years , and they last about forever, and are easy to clean off any old dope residue. Keith
Re: Drying Racks
« Reply #8 on: January 16, 2012, 08:38:40 PM »
Well, you can go all crazy like Allan and build showpiece jigs or just build some out of scrap balsa and 1/32" plywood like I do.
Mike Griffin
Re: Drying Racks
« Reply #9 on: January 16, 2012, 09:31:04 PM »
Some great ideas here guys...thanks...seems like everyone has their own favorite method and they all work...appreciate the time you guys took for the answers...
Offline Joseph Patterson
  • AMA member- Supporter
Re: Drying Racks
« Reply #10 on: January 16, 2012, 10:12:13 PM »
AH! Allan too purty!!
  Doug
Re: Drying Racks
« Reply #11 on: January 17, 2012, 08:17:56 AM »
I like Allan's idea as it can be reused. H^^
Re: Drying Racks
« Reply #12 on: January 17, 2012, 10:01:37 AM »
The other advantage of Allan's setup is that it can hold things like flaps very straight so you don't run as much risk of painting in a warp.
Offline Ward Van Duzer
Re: Drying Racks
« Reply #13 on: January 17, 2012, 10:18:10 AM »
Don't forget, if you are going to make permanent jigs all your hinges have to have the same spacing.
That's why I make junk jigs for each job. K & S brass strips bent and CA'd to junk balsa...
W.
Re: Drying Racks
« Reply #14 on: January 17, 2012, 10:21:29 AM »
A@ Randy,, yeah thats one reason I used the brass strips in the hinge holes, and a solid heavy base
@ Ward,
I like the heavier base, I can spray the part without it dancing across the bench from the air pressure,, when I tried balsa it would not sit still
