  • July 16, 2025, 10:41:35 PM
Author Topic: doping a wing  (Read 1874 times)
Offline Bootlegger
doping a wing
« on: January 25, 2019, 08:54:52 AM »
  A few days ago I doped a skinned foam wing, and dropped the thing on the floor/ground, what is the best way to get the crud off the wing?  Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: doping a wing
« Reply #1 on: January 25, 2019, 09:33:50 AM »
What sort of crud?  If it's sandable crud (household dust, balsa dust, and balsa shavings) I'd be tempted to brush it off as best as I could with my hand, paint over it, and sand the mess flat.
Offline Bootlegger
Re: doping a wing
« Reply #2 on: January 25, 2019, 09:52:12 AM »
   Tim, so much is crud that you find on the floor of your shop, dust, balsa shavings, just crud, I am gonna try to brush as much off as I can, then go from there, thanks for your reply..
Gil Causey
AMA# 6964
Re: doping a wing
« Reply #3 on: January 25, 2019, 11:58:19 AM »
Unless someone else weighs in I think that's the best you can do.  If the crud is just dust and balsawood, then it should actually sand pretty well.  My worry in my shop would be metal shavings or large sand grains that would roll under the sandpaper and make big scratches -- but even then I think the only way to find them would be to give it a whirl, and maybe pick the offending nuggets out with a pin under a strong light.
Do brush off any cats or small children that may be stuck to it, though.
Re: doping a wing
« Reply #4 on: January 25, 2019, 12:39:06 PM »
Put a coat on the top and lay the wing upside down on the floor.  Now finish over it and tell everybody that they are a new form of vortex generators. LL~
My last contest design before my great trip into the wilderness was names the "Surveyor"  It was named that because of all of the benchmarks on the wings. :X
Offline Warren Walker
Re: doping a wing
« Reply #5 on: January 25, 2019, 02:05:37 PM »
Try 75% thinner 25% retarder, soak a rag and wipe it off.
Re: doping a wing
« Reply #6 on: January 25, 2019, 04:21:05 PM »
   Block sand it when it is completely dry. Coating over it may trap some stuff that could come back to haunt you later. Just block sand that first coat completely off and wipe down with a tack rag.
Offline Bootlegger
Re: doping a wing
« Reply #7 on: January 27, 2019, 06:40:01 PM »
  Guy's, I sure do thank y'all for the reply's, I let it dry for a few days, sanded it, then today I doped it again, gonna let it dry over night and see how it looks, most of the crud sanded off.  Oh, didn't find any small children or other animals any where on it..  LOL
Gil Causey
AMA# 6964
Re: doping a wing
« Reply #8 on: January 27, 2019, 06:56:29 PM »
... then today I doped it again ...
The first time around I read that as "then today I dropped it again".  WHAT??.  The I re-read it -- it sounded much happier the second time.
Re: doping a wing
« Reply #9 on: January 28, 2019, 01:41:47 AM »
I do that all the time.
