  • June 18, 2025, 07:57:07 AM
Author Topic: Dope finish...Need Help  (Read 1137 times)
Offline Bill Diedrich
« on: August 21, 2006, 07:14:42 PM »
Recently ordered some medium silk span from Joe Mader @ S & S Hobbies and some Randolph's non-taughtening nitrate dope  from Aircraft Spruce & Specialty. this past weekend I attached the silk span with there non-taughtening dope, when dry after about 3 hours applied butyrate clear dope to finish shrinking the covering and it didn't happen......Silk-span is now very loose and sagging, wrinkles all over. where did I go wrong, I thought I remembered how to do it after 40 years, like riding a bike you never forget, but I guess I was wrong on this one.
"To be old is to be wise"
AMA 867732
Ventress, Louisiana
Offline RC Storick
Re: Dope finish...Need Help
« Reply #1 on: August 21, 2006, 07:17:07 PM »
Did you put the silk span on damp? Then pull tight and let dry first before the dope?
« Reply #2 on: August 21, 2006, 07:25:34 PM »
Ditto what Sparky asked.
Bill <><
Offline frank carlisle
« Reply #3 on: August 21, 2006, 07:35:51 PM »
you may still be able to get it to shrink and taughten up. Spritz it with water from a spray bottle.
Frank Carlisle
