  • June 24, 2025, 02:56:54 AM
Author Topic: Dope and C.A.  (Read 1579 times)
Offline steve pagano
Dope and C.A.
« on: January 16, 2007, 02:22:15 PM »
Does dope and c.a. have a long shelf life?
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Offline Leester
Re: Dope and C.A.
« Reply #1 on: January 16, 2007, 02:28:14 PM »
C/A should be used fairly quick, but I've heard keeping it in the fridge helps it last longer. As far as dope I'd say as long as it's sealed so no air gets in it should be fine.
Leester
ama 830538
Re: Dope and C.A.
« Reply #2 on: January 16, 2007, 02:31:18 PM »
sounds good to me thanks  ;D
A.M.A. 820-823
Re: Dope and C.A.
« Reply #3 on: January 16, 2007, 03:11:11 PM »
From what I have heard, CA in the fridge works well if the bottle is sealed. Since it is activated by moisture, the storage of open containers ie using it then putting in fridge when done building , would be counterproductive because of condensation  from the heating and cooling cycles
Just what I have read and seen, your mileage may vary
Offline Chris Gilbert IRL-1638
  • EI-1638
Re: Dope and C.A.
« Reply #4 on: January 17, 2007, 06:39:29 AM »
After a long layoff I'm finishing with some dope that I purchased when I was flying 20+ years ago. The gallon can it came in looked awful - well rusted, the dope itself was a little thick, but nothing that some thinner didn't resolve when I started building again. When I put it away there was maybe a half gallon in the tin and I've had no problems using it since starting to build and fly again.
IRL-1638
Offline peabody
Re: Dope and C.A.
« Reply #5 on: January 17, 2007, 07:20:24 AM »
Remember that what evaporates from dope is thinner...add some and you should be okay, unless it has the consistency of a brick....
Offline frank carlisle
Re: Dope and C.A.
« Reply #6 on: January 19, 2007, 05:29:37 PM »
Dope doesn't last long at my house.
CA stays a little longer.
Frank Carlisle
