  • June 21, 2025, 04:56:11 AM
Author Topic: PA.61 in a Score  (Read 1171 times)
PA.61 in a Score
« on: July 21, 2016, 07:27:59 PM »
        I just got me a Top Flite Score would a PA.61 engine ok for this model?
Re: PA.61 in a Score
« Reply #1 on: July 21, 2016, 09:54:07 PM »
I don't see why it wouldn't. The Score is pretty large and not particularly lightweight. I've seen them fly pretty well with ST 51's and Enya 61's. The PA seems like a good fit.
Offline Mike Scholtes
« Reply #2 on: July 21, 2016, 11:24:18 PM »
I had an Enya 61 in my Score and it was an excellent match. The PA should be just as good. If it is rear exhaust there may be an issue getting the header and pipe  to fit below the fuselage since it is not designed with a pipe tunnel. If the PA is side exhaust (as my Enya is) then no problem. Or use a header muffler without a pipe if RE.
« Reply #3 on: July 22, 2016, 07:46:14 AM »
 I appreciate your reply`s. The engine I have is a rear exhaust and I will be buying a Header muffler as suggested by Mike.  I do have a tuned pipe system but will save it for another project. I just want to know if  I can handle a big stunter with a PA.61.
