  • July 30, 2025, 12:19:29 AM
Author Topic: Don't question Pat, Mark, and Randy!!!  (Read 2378 times)
« on: March 31, 2012, 05:52:26 PM »
I got to put up a few flights this afternoon with my flying coach Jim Lynch.
We were chasing that elusive needle setting on my LA .46 that is bolted in my Vector. Jim said he did not know a whole lot about these engines. (He is a PA / AeroTiger kind of guy)
So he called Randy Smith while we were at the field. After he hung up the phone he told me that I needed a 12 in prop.
Well I said to Jim I just happen to have one that I pulled off my Tutor II that had a brand new LA 46 and it did not like it very much. (cause the engine is not fully broken in) Lesson learned.
We bolted the 12.25x3.75 APC on the Vector and it liked it a lot! The plane seemed to needle better, and the engine seemed real happy swinging it.
The next time these guys tell me what prop to put on a engine I am going to bolt it on. If I don't have it my box I will order it. BW@
Thanks guys! H^^
Re: Don't question Pat, Mark, and Randy!!!
« Reply #1 on: March 31, 2012, 06:43:38 PM »
Paul, glad it worked for you,,
« Reply #2 on: March 31, 2012, 09:26:09 PM »
Randy knows his stunt.
« Reply #3 on: March 31, 2012, 09:37:52 PM »
Or in this case, Pat.
« Reply #4 on: March 31, 2012, 09:46:00 PM »
  I have been relaying the virtues of the APC 12.25X3.75 prop ever since it was introduced to me by Jim Schuett at a SIG contest years ago. It's one of those magic props that seems to work on anything over a .46 displacement that is a modern engine with schurle porting. It was with this prop on a ST.51 in my Charmer that I first experienced the advantages of a high RPM, low prop pitch set up for flying in the wind. Do a search on the list and find Ted Fanchers post with the story of how this prop came about. Very interesting!
   Good luck and have fun,
« Reply #5 on: April 01, 2012, 12:25:37 AM »
Indeed, but I musta missed part of the story.
« Reply #6 on: April 01, 2012, 02:13:22 AM »
RSM 11x6 is the best prop ever for the vechor40 and la46 combo.....just saying......
Offline Allan Perret
  • Proverbs
« Reply #7 on: April 01, 2012, 06:08:29 AM »
Would like to read about this, but need more info on what to search for.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #8 on: April 01, 2012, 11:57:30 AM »
APC 12 1/4x3 3/4,
I've used that prop for a lot of things, Stunt and R/C Pattern. It makes a host of engine/model combos work well.
Chris...
« Reply #9 on: April 01, 2012, 02:20:55 PM »
APC 12 1/4x3 3/4,
Chris...
I used that prop exclusivley for 2 years - then went to the RSM prop and never went back......
« Reply #10 on: April 01, 2012, 02:25:36 PM »
Hi Rootbeard,
Those guys you mention (well maybe not Mark! LOL!!) have years of experience flying at the top levels so I always listen to them. ;D
When it comes to engines, Randy is my "go to" guy.  Never been wrong, so far!
BIG Bear
RNMM/AMM
Offline Pat Johnston
« Reply #11 on: April 03, 2012, 06:47:58 AM »
Now to make a wood prop clone of it.  Reduce the GP a little.  Great prop to drop on the LA46 as a base line.  This will pull like a horse.
Pat Johnston
Skunk Works
« Reply #12 on: April 03, 2012, 09:55:21 AM »
Pat Johnston
Skunk Works
which brings to mind exactly that, on a certain Oriental I remember,, what a truck! that baby was at flying speed as soon as you let it go,, I think I almost pulled Pat off his knees one time launching it LOL LL~
Offline petermick
« Reply #13 on: April 17, 2012, 03:50:24 PM »
I plan on putting an LA 46 on a Pathfinder profile.  I've seen articles suggesting the APC 12.25 X 3.75 prop.  I went to the APC website looking for this size.  No luck.  Who sells this size prop.
Peter Mick
« Reply #14 on: April 17, 2012, 04:28:44 PM »
Peter, here are a couple options, a few minutes on Google resulted in>
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX1577
http://www.rcplanet.com/APC_Propellers_LP12338_12_25x3_75_Sport_Propeller_p/apclp12338.htm
and then on APC Landing products ( manufactures site)
http://www.apcprop.com/ProductDetails.asp?ProductCode=LP12338
It helps to know that APC's website and company name is "Landing Products" then use the "online store" "propellor list" options
hope this helps,,
« Reply #15 on: April 17, 2012, 04:34:02 PM »
Peter Mick
Peter,
I suggest that the engine is fully broken in before you try and swing that prop.
Ask me how I know..... HB~>
Offline Kim Mortimore
« Reply #16 on: April 18, 2012, 06:55:40 PM »
Paul,
How's the ground clearance on your Vector with the 12.25?
Kim Mortimore
Santa Clara, CA
« Reply #17 on: April 18, 2012, 07:01:13 PM »
Kim,
I did have to tweek them but there is enough.
I can take off on grass, and I could or should put on a little larger wheel.
