  • July 18, 2025, 01:09:21 AM
Author Topic: O'Toole Special  (Read 3245 times)
Offline John Bocksnick
O'Toole Special
« on: January 13, 2016, 08:03:42 AM »
Does anyone have a picture of Ron O'Toole's "O'Toole Special", and specifications?
John Bocksnick
Offline Alan Resinger
Re: O'Toole Special
« Reply #1 on: January 13, 2016, 11:32:12 AM »
John,
The plans are available from PAMPA.  I've attached a PDF of the plans that I drew a few years back.
Alan Resinger
« Last Edit: January 13, 2016, 08:11:31 PM by Alan Resinger »
Offline Garf
    • Hangar Flying
Re: O'Toole Special
« Reply #2 on: January 13, 2016, 12:12:46 PM »
Never heard of this one. What does it look like?
Offline tom brightbill
Re: O'Toole Special
« Reply #3 on: January 13, 2016, 01:08:23 PM »
Some info-
http://stunthanger.com/smf/classic-planes/tucker-special-question
Mine is in process , about half done.  RoJett 40 power.
AMA 34849
Re: O'Toole Special
« Reply #4 on: January 13, 2016, 01:28:04 PM »
Here ya go!
Re: O'Toole Special
« Reply #5 on: January 13, 2016, 02:34:31 PM »
The Tucker in the picture above (Don McClave's) is the Tucker Special, like the RSM kit.  The O'Toole Tucker is as the print attached and discussed by Alan, in reply 5.  They are not the same plane, as Alan noted. It's easy to get the two confessed as Don built the one style as shown in the above photo, and he and Alan also did the plans for the other (O'Toole) version.
AMA 34849
Offline Tom Niebuhr
Re: O'Toole Special
« Reply #6 on: January 13, 2016, 04:21:05 PM »
Ron O'Toole was among several St Louis fliers that built the original "Tucker Special" They were built with wing gears and fuselage gears. Some of these airplanes were hanging in Shaefer's Hobby Shop in St Louis and still might be in the new shop. Sparky would know.
As stated by Tom above, Ron O'toole also built his newer version that is a completely different airplane. Pampa has the plans.
AMA 7544
Re: O'Toole Special
« Reply #7 on: January 13, 2016, 06:48:02 PM »
   Here is mine built in 2002. Merco Rustler/40. I still fly it and it is in good shape. It was one of the early RSM kits with 2" wing offset.
EddyR
Re: O'Toole Special
« Reply #8 on: January 13, 2016, 08:32:35 PM »
To clarify the Tucker linage I'll try to set the record straight.  I grew up in the St. Louis area and flew at Buder Park in the 60's.  The original Tucker (designed by Bob Tucker) had a fuselage mounted LG and had either a 3/4" or 1" assymetrical wing.  The model was loosely based on the Italian Macchi seaplane racer, the MC-72.  The model had the distinctive Macchi vertical stab with the tail wheel mounted in the sub fin.  The original had a very deep sub rudder.  Later models reduced the sub rudder.  These were pre 1960 models.  In the early 60's the newer versions started to sport wing mounted LG.  By the time the published version came out in 63, the wing asymmetry got to a full 2".  My thinking is that this change came about because of Bill Werwage's Ares success.  The O'Toole Tucker was a modification of the original Tucker to look more like the Supermarine racer of the same vintage as the Macchi racers.  I think Ron O'Toole told me that the O'Toole version was built for the Dallas Nats in the early 60's.
Offline Tom Niebuhr
Re: O'Toole Special
« Reply #9 on: January 15, 2016, 12:57:08 PM »
Alan,
I am surprised that we never met. I was in the St Louis area from the fall of 1964 until 1973.
You supported what I said about Tucker with both fuselage and wing gears.  I was surprised about the asymmetry. I always wondered it the Tucker would be even better with only 1" difference in the wings. It is still  a very could Classic choice with 2" difference.
I wonder is there is anyone left that could substantiate the 1" versions. I know that there are only a few of us left from the old St Louis Yellow Jackets club.
AMA 7544
Re: O'Toole Special
« Reply #10 on: January 16, 2016, 02:17:47 PM »
Tom,
I lived down in the Festus/Crystal City area so didn't fly all that much at Buder. Left the area in 65 when I went into the service.   I think Ron told me about the differences in asymmetry when Don McClave and I were doing the article for the O'Toole Tucker for Stunt News.  Don had a picture of George Aldrich doing appearance judging at the Dallas Nats and wanted to know if I knew anything about the model.  I had a vague rememberance of seeing it back in the early 60's.  I called Ron and talked to him about it and about the Tucker 4 that Gary Zeller flew.  As I recall Ron was not wild about Gary's model.  I have attached a PDF of the Original Tucker with the deep sub rudder.
Alan
« Last Edit: January 17, 2016, 04:51:05 PM by Alan Resinger »
