  • June 21, 2025, 10:04:10 AM
Author Topic: Does anyone know the part number for Boca bearings  (Read 1518 times)
Online RC Storick
« on: September 14, 2019, 09:43:06 PM »
I am looking to order some bearings from Boca for St V.60 If you have the link or Boca's part number please let me know
Offline Richard Imhoff
Dick Imhoff  AMA 58502
Combat, Racing, Stunt, and big time fun flyer, and Maybe a bit of carrier.
Online Carl Cisneros
Re: Does anyone know the part number for Boca bearings
« Reply #2 on: September 15, 2019, 11:22:24 AM »
Go the way that motorman suggest in buying them
I do it the exact same way and I have NEVER had a wrong bearing delivered.
I use the bearings with the polymite plastic cages and I also get the front bearings with the rubber seals and just pop one off and place the remaining
sealed side towards the prop.
Also, if you have a motor that they do not have listed and new to them then they will USUALLY give you a discount on future orders.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Offline Gerald Arana
« Reply #3 on: September 15, 2019, 07:44:27 PM »
I can't find my Boca catalog...... or I'd give you the number.
Next best thing is to remove the bearings and ask for a set in kind.
Good luck, Jerry
« Reply #4 on: September 17, 2019, 02:20:39 PM »
I have them in stock  !
Online Dennis Toth
« Reply #5 on: January 23, 2020, 06:49:25 PM »
Robert,
Was doing a search for the ST 60 bearings and came across the following - Boca Bearing has them listed as ST (OLD) 60.
The front is the same as ST46. It's a 607 which is 7mm ID, 19mm OD & 6mm wide.
The rear is a 16002 which is 15mm ID, 32mm OD & 8mm wide
Best,   DennisT
« Reply #6 on: January 27, 2020, 12:49:10 PM »
Randy  678 407 9376
Sorry, this topic is locked. Only admins and moderators can reply.
