General control line discussion => Open Forum => Topic started by: RC Storick on September 14, 2019, 09:43:06 PM
Title: Does anyone know the part number for Boca bearings
Post by: RC Storick on September 14, 2019, 09:43:06 PM
I am looking to order some bearings from Boca for St V.60 If you have the link or Boca's part number please let me know
Title: Re: Does anyone know the part number for Boca bearings
Post by: Richard Imhoff on September 14, 2019, 10:20:52 PM
hereis his list for super tigre
https://www.bocabearings.com/products/bearing-applications/rc-engine-bearings?ItemMakes=SUPER_TIGRE&ProductType=2
Post by: Carl Cisneros on September 15, 2019, 11:22:24 AM
Go the way that motorman suggest in buying them
I do it the exact same way and I have NEVER had a wrong bearing delivered.
I use the bearings with the polymite plastic cages and I also get the front bearings with the rubber seals and just pop one off and place the remaining
sealed side towards the prop.
Also, if you have a motor that they do not have listed and new to them then they will USUALLY give you a discount on future orders.
Carl
Post by: Gerald Arana on September 15, 2019, 07:44:27 PM
I can't find my Boca catalog...... or I'd give you the number.
Next best thing is to remove the bearings and ask for a set in kind.
Good luck, Jerry
Post by: RandySmith on September 17, 2019, 02:20:39 PM
I have them in stock  !
Post by: Dennis Toth on January 23, 2020, 06:49:25 PM
Robert,
Was doing a search for the ST 60 bearings and came across the following - Boca Bearing has them listed as ST (OLD) 60.
The front is the same as ST46. It's a 607 which is 7mm ID, 19mm OD & 6mm wide.
The rear is a 16002 which is 15mm ID, 32mm OD & 8mm wide
Best,   DennisT
Post by: RandySmith on January 27, 2020, 12:49:10 PM
Randy  678 407 9376
