  • July 21, 2025, 11:22:55 PM
Author Topic: Does anybody know (banshee) questions.  (Read 2462 times)
Offline jim gilmore
« on: July 13, 2009, 04:04:00 PM »
Way back when I wqas a lot younger I often Flew at Flushing meadow park and watch Big Jim flew a pair of "pink" modified Sig Banshee's. Does anybody know what all was modified on them? I though he lenghtened or shortened the nose but not sure what  else was done to them. And theylooked pink to me but I am color blind so they could have been a different shade altogether.
Offline peabody
Re: Does anybody know (banshee) questions.
« Reply #1 on: July 13, 2009, 04:29:06 PM »
Hi Jim...
PAMPA products has copies of the "Fancherized" Twister....good mods to either a Twister or a Banshee....
« Reply #2 on: July 13, 2009, 07:17:42 PM »
I think that the plans talk about cutting the nose if you are going to use a type of engine. I can not remember if it calls for cutting it back if you are going to use anything other then a Fox 35. Someone told me about it. Not sure if you need to do anything else to them.
« Reply #3 on: July 13, 2009, 10:10:49 PM »
Banshee mods are easy. Slide the wing 1" forward and add 1" to each side of the stab/elev assembly. Great flying models.
Dwayne
« Reply #4 on: July 14, 2009, 05:36:31 AM »
Or just lop an inch and a half off the nose and add 1 inch to the stab/elev, either way these are the mods you want to do
« Reply #5 on: July 14, 2009, 11:31:56 AM »
The standard mod at Flushing Meadows back in the day for Banshees was to shorten the nose 1". Big Jim did indeed have those Banshees. I built a couple of them and never liked the planes.
Offline jim gilmore
« Reply #6 on: July 14, 2009, 01:19:34 PM »
See this how I learn stuff......
No I'm not planning on building a banshee though I though they flew well when I watched them.
[/quote]Banshee mods are easy. Slide the wing 1" forward and add 1" to each side of the stab/elev assembly. Great flying models.
Or just lop an inch and a half off the nose and add 1 inch to the stab/elev, either way these are the mods you want to doquote]
Now I know what I should have done to the akromaster. I moved the engine back to get better balance but doing so makes the nose area for my tank very short. So if I had instead moved the wing 1/4 inch forward or so....
steven yampolsky
« Reply #7 on: July 14, 2009, 01:51:41 PM »
Besides the suggestions made by others, add one(or two) extra bays to the wing.
Offline jim gilmore
« Reply #8 on: July 14, 2009, 02:45:25 PM »
Just out of curiosity here I am not building a banshee but I do not nor have a seen a good photo of one that tells me it's layout.It is constant chord wing right ?
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #9 on: July 14, 2009, 07:20:19 PM »
That is correct sir.
This is my Banshee.  I lopped an inch off the nose and love the way it fly's,
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
steven yampolsky
« Reply #10 on: July 14, 2009, 08:45:13 PM »
Offline jim gilmore
« Reply #11 on: July 14, 2009, 09:45:14 PM »
Thanks guys.
Harleyman I have other photos of your plane Just didn't know it was a banshee. That color pattern kida screams out pt-19 to me.
Offline jim gilmore
« Reply #12 on: July 14, 2009, 10:13:26 PM »
As I said I am NOT building a banshee.
I am though working on a new build or will be in about 2 weeks. Have new wood and printer cable waiting at my po box. My choice is to build something for an .09. 1/20 wood for ribs and sheeting using My choice of wingbuild. Straight chord.
Choices are either magician/mustunt1/shark402/banshee/ scaled down To about a 30 inch wing without tips added. I'll prolly use tileprint to print out my plans when I'am ready. I do like wing mounted landing gear though.
