Doc!
I flew the Mako Jet for the first time last night! Finally... Weather here has been gnarly.
I wanted to mention this since the airfoil on both the MJ and your P-47 both have the same genesis in the same design approach. The MJ produced nice corners with clean exits for squares and triangles. Tracking was effortless in the rounds. Bottoms were consistent 3-5' with ease. What was interesting, that with the good corner, the level flight was super stable to the point of practically "hands off" flying. In fact, even thought the CG is right on the 20% position, the plane's stability feels like it is nose heavy. That is likely why the tracking in the rounds is so good, along with the consistent bottoms.
The airfoil uses and elliptical front with the total high point at 20% back. The MJ uses an 18% thick section in the root and a 16% thick tip for reduced drag at the tips to help in windy turbulence. Time will tell just how well this last point works. Your P-47 tips transition naturally to a relatively thin section, so that is similar in effect.
If your P-47 has anywhere these charactoristics, it will be a total winner.
Pat Johnston
Ever Designing
Skunk Works
