  • July 17, 2025, 01:20:16 AM
Author Topic: Do you wrap silkspan over wing and elevator joint or do you use a separate piece  (Read 1084 times)
Offline paulwells66
Do you wrap silkspan over wing and elevator joint or do you use a separate piece or do you put nothing at all im the joint?
Another question in which you can get as many answers as there are modelers.  Through the years I have done it many ways.  A lot depends on the design.  On full fuselage designs I have even laid fibre glass and resin in side the fuselage extending up on the sides over the joint.  Usually the leading and trailing edge have a joint.  Take a little time and go read through the construction articles of planes.   I-beam wings usually don't have a center section joint  also take apart planes. D>K
Offline paulwells66
just a combat streak where the wing to fuse joint is not perfect..a few little gaps.don't like using filler. thought I would either a) wrap a small piece of silkspan all the way around the joint or b) wrap the piece covering the fuselage side into the seam
If you have gaps between wing and fuselage, cut and sand pieces to glue into the joint.  Back in the day I remember kits telling me to lay a strip of cloth along the wing/fuselage joint.  I learned to do it inside the fuse before putting top and bottom sheeting on.  It all takes practice and thought.  It is all called a learning curve.  When I myself stop learning is when I go into the incenterator. D>K
Offline paulwells66
I was thinking the same thing as I glued the wing..."boy I should have waited to sheet the top of the fuselage regardless of what the plans say :)
Offline paulwells66
Am I confused? You asked about wing and elevator, I assumed you meant stab and elevator. If stab/elevator my answer stands. If wing and fuselage, not sure what you are talking about. Any holes in the wing to fuselage joint, I fill with appropriate size balsa. D>K
talking about both...and referring to using silkspan to make the seam clean and a smooth transition. like a fillet
