Hi. I just managed to pick up three incomplete/damaged Veco .19s and was after some advice. These are the bushed version, unlike those currently available.
One looks to be in pretty good condition apart from a crack through to the mounting hole in the venturi housing. This is an R/C version without the carb. It turns over nicely, looks really neat and has little evidence of being mounted. The other two crankcases have enlarged mounting holes but this one looks great in that department.
No.2 engine has a similar crack, but apart from the enlarged mounting holes seems ok. No carb. Still turns over ok, although stiff. Haven't oiled it up and fitted a plug to try comp at this stage.
No 3 is a C/L version and looks rough. Enlarged holes and missing most screws. The venturi appears to have been filled with JB Weld to try to reduce the diameter. Does it have an insert originally? On removing the two remaining head screws I discovered that the top flange of the liner has all but been completely snapped off, probably by trying to lever it out with a screwdriver.
My questions are, first of all, are these decent engines?
Is it worth trying to get one mobile?
What's the best way to remove the liner without harming anything? Obviously this has to come out to remove the piston & crank.
Are parts available? MECOA has parts for the BB version, but does anything interchange?
I'd appreciate any advice/opinions. They only owe me $10 the lot, so it's not a big investment if you think they're best relegated to the parts draw.
Cheers.
Rod.
