  • June 26, 2025, 10:12:12 PM
Author Topic: No more loose engine bolts  (Read 2325 times)
Offline Keith Spriggs
    • khspriggs
« on: March 14, 2007, 11:35:12 PM »
This should fix it once and for all.
Offline Wayne J. Buran
Re: No more loose engine bolts
« Reply #1 on: March 15, 2007, 04:22:58 AM »
Nice safety wiring but drilling the holes had to be a pain.
Wayne Buran
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Offline Jim Oliver
« Reply #2 on: March 15, 2007, 06:45:55 AM »
Ny-lok nuts---the lazy man's way!! ;D
Jim
Jim Oliver
AMA 18475
Offline Busby
  • ACE
« Reply #3 on: March 15, 2007, 09:07:55 AM »
Locktight works very well also.
I have engine bolts that have not been tightened in 3 years.
You just have to retighten them after the first time you run it.
Busby
Marshall Busby
    • khspriggs
« Reply #4 on: March 15, 2007, 09:27:39 AM »
Really I didn't do this as a practical solution. Just a novelty done by someone with too much time on their hands.
Offline Dennis Vander Kuur
« Reply #5 on: March 15, 2007, 02:22:35 PM »
Unfortunately, the clamping and the engine vibrations will tend to compress the wooden engine bearers and then the engine may no longer be held tightly by the bolts. This may lead to even more vibration by the loose engine. The safety-wired nuts won't come loose but the engine may be loose.   HB~>  Sorry.
DennisV
Dennis L. Vander Kuur
AMA 29292
Offline Louis Rankin
« Reply #6 on: March 15, 2007, 04:08:06 PM »
Don't let the AMA see this, they will make it a safety requirement.
Louis Rankin
Somerville Tennessee
AMA 10859
Offline Bill Gruby
« Reply #7 on: March 15, 2007, 06:02:50 PM »
To all;
   As Keith has stated ,he did this because he had time on his hands. This is how a lot of innovations occur, someone has time so they put it to good use. I have been priviledged to see some of Keiths' other work, he is one of the most talented machinists I have seen in a long time. Keep it up Keith, I for one will never get tired of seeing what you come up with. Surprise me some more OK?
"Billy G"    H^^
Bill Gruby
AMA 94433
MECA 5393-10
Offline Bob Disharoon
« Reply #8 on: March 15, 2007, 06:13:09 PM »
Now...lets see....bolt, backing plate ,split washer, nut, nylock,loctite, AND seizing wire..try that..it might do the trick!..just kidding, BOB S?P S?P
« Reply #9 on: March 15, 2007, 09:10:45 PM »
Now Keith, not to be sarcastic as I like what you have done.  But, what if you can't get to the nut end of the bolt.  I just lost a bolt on a flight because I did not take time to check them before the first round of OTS yesterday.  Got the pattern in tho.  Keep up the good work.  DOC Holliday
« Reply #10 on: March 16, 2007, 06:10:29 AM »
That really is nice work..my eyeballs would fall out if I tried that!!
