  • July 17, 2025, 02:08:55 PM
Author Topic: Insides vs Outsides different, what to do?  (Read 801 times)
Offline Larry Renger
« on: August 15, 2010, 05:41:50 PM »
It seems to be consistent that my Sky Sport design turns outsides better than insides.  I have two .061 models and now the .15 size one.  I can fix it on each model by biasing the bellcrank or handle, but I would really like to build perfect trim into the design.  My thoughts are to tweak either or both the thrustline and the elevator angle setting.
Anyone out there with a clue?  (I am told that Jamisons do the same thing, and I am just finishing up one of those, too, so HELP??)
Re: Insides vs Outsides different, what to do?
« Reply #1 on: August 15, 2010, 05:56:26 PM »
seems to me that you are building the control system with incorrect geometery - I am only guessing that you are using 90 degree horns - which will make this happen.
There are a few good articles on how to build symetrical systems - i'll see if i can scan one in.
Offline Jim Thomerson
« Reply #2 on: August 15, 2010, 06:11:06 PM »
I had an extreme problem with a 40 size airplane.  I corrected it with 3 degree shims under the engine.  the thrust-line was that much off.
