  • July 18, 2025, 06:21:12 PM
Author Topic: Designing your own C/L airplane  (Read 1446 times)
Offline Jerry Leuty
« on: July 17, 2011, 03:41:11 PM »
  I know that when we were kids most of us got the engines off those Cox plastic models and either got a Scientific kit or designed and built a tiny model that more or less flew. But that set up the glue of modeling that has lasted for the past 50 or 60 years now. I have been back into modeling since the spring of 1999. My first 12 or so planes did not make it much past a few flights. Usually the engine would flame out in the overheads, a wing was warped and showed up at a most inopportune time in flight, or my handle was out of adjustment and I did not compensate for that in a outside square manuever. Now I have around a dozen planes RTF and that many more wings and kits to build with engines for all. This past Christmas I was in Roy's Hobby Shop in Hurst, Texas and I laid eyes on the Brodak Legacy. Their price was about 15% less than I could order it from the manufacture. I laid out the plans and studied them closely. I had an extra S/Chipmunk foam wing panel that I had purchased from Model Wings of Marietta, Ga. some 10 years ago. It was about 11% shorter but the exact same airfoil as the plans showed. So I built a .40 size version of the Legacy. It flies wonderfully. I am looking forward to feeling better and building two full size versions of the kit. I have a NIB LA .46 and a NIB Avastar .46 to power each with. These planes will make a better presentation of the pattern than anything that I have ever flown. I have always wanted to design and build a CLPA model. And I have by using some tried and true numbers. But I simply cannot improve on the appearnace or performance of this design. Allen Brickhaus did a superb job on designing this model. When you have the best that you know of that pleases you then why build and fly anything else? Check them out......Jerry
Re: Designing your own C/L airplane
« Reply #1 on: July 17, 2011, 04:34:32 PM »
you will struggle with a 46 in the legacy - unless you build it SUPER SUPER light....
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: July 17, 2011, 05:22:05 PM »
You musta missed he's building 40 size Legacy"s
Offline Jerry Leuty
« Reply #3 on: July 17, 2011, 05:30:55 PM »
   So what do you think Allen; will a Avastar .46 power the Legacy kit? My M-O is to build and fly mostly .40 size planes. I do have a .25 FP on a Ring Master to use at the Ring Master Round Up. I also have a few new .35 FPs in the box. I doubt that I will ever build or fly anything any bigger than a .46 size plane. At this point I can shrink the wing and fuselage by 15% and still have a nice flying .40 size ship as I have already done that. Hump, I will take into consideration that the .46 may not be powerful enough for this plane. Bench running the Avastar it seems to run real strong. Light will be the key I suppose..........jerry
« Reply #4 on: July 17, 2011, 07:34:28 PM »
"looking forward to feeling better and building two full size versions of the kit."
Guess you missed this line in his post!
the 46 wil be slightly underpowered - not sure on the Aviastar - but I built one with an LA and it struggled - Super Tigre 51 sorted that out - and now I fly an electric one which has TONS of power.
« Reply #5 on: July 17, 2011, 09:52:24 PM »
 I definitely agree that a .46 isn't quite enough oomph. The Saito .56 with a 12-6 Rev Up prop is an ideal combination for the full size Legacy. y1
