General control line discussion => Open Forum => Topic started by: RC Storick on March 01, 2013, 09:07:51 PM
I have given back the power to delete your own posts. however I don't appreciate some that whine on SSW about it.
Is the delete you own post button working now for everyone? You will not be able to delete a thread
I will test by deleting this post.
No, it doesn't work, or at least I don't know what button to push. I see an added "edit" icon that I don't recall seeing before, but that just allows me to edit.
Its still there.....
Test.
Nope, still here. Can't find the delete button.
What is this?
(On edit: well, it's not the delete button!)
What is this?
Exactly, it's a second edit button. If there's a delete button, I didn't see it.
Its working now. A red X next to modify in the upper right hand corner. So easy even a caveman can do it.
This caveman doesn't have a red X.
I see nothing like that, look at my screen cap.
I tried all the obvious (clearing cache and cookies, logging out and back in), and Firefox, Chrome in addition to Safari, but no go.
Brett:
Drill a bunch of holes in it, then give it a coat of Dr. Good. LL~
There's one on mine, `cept there's no room to type anything. :-\
I will adjust it some more
Brett:
Now that is funny!!!!
try now
try now
Test for hypothetical delete button....
None visible....
It works fine from here, Robert, I've tested it twice.... works as advertised, good job.
dale g
None visible....
Yhat has to be on your end Brett. Should fix its self on next log in
It didn't, I cleared the cache, cleared cookies (which logs out), then logged back in.
My screen caps show what I see, is it on there?
Well it has to work now
That works fine. What is "split topic"
Oh you gave me (and maybe everyone) mod capabilities? I can delete your posts, too...
2 minutes later - back to not working. Probably better that no one can delete posts than allow everyone.
should be gone now. I am just tying to give everyone the button to delete their own single post not topics
Right, now I can't delete anything again.
Can I delete a post?
... Nope, I don't think I can.
Using Firefox on Windows XP.
Same thing with IE8 on XP
No delete button here, either. And I HAVE logged out and back in. And cleared the cache. And spoken soothingly to the screen. And yelled a bit. And ....
BTW, I do like the "Modify in place" feature that you have added.
Worked for me
It is still working fine here this morning, Robert. After posting, I get the quote, modify and remove buttons. I'm using Internet Explorer and Windows Seven.
dg
try that
try that
No luck.
No luck.
I know it works now. Just dont split topics. There has to be a issue between our computers. I will take down the whole system later and redo all permissions
I know it works now. Just dont split topics. There has to be a issue between our computers. I will tkae down the whole system later and redo all permissions
It works now (same as last night). I can now modify other people's posts and delete them, too, so I wouldn't leave it that way!
its only for you. so dont delete anyposts except your own. There is some issue between our computers. I will fix it later
OK, I think I have enough restraint. I have managed to not wreck the PAMPA website for the last 8 years, and not delete anyone even though it was tempting, so I am probably safe enough.
I know..
Now I have a Remove button.
Does it have an "Are you sure" dialog?
It wouldn't be the first time I click the wrong button or link...
If you make a mistake you should be able to remove your comment and only your comment
WOO HOO! A remove button!
I have the red X remove option on my private messages only.
