  • June 21, 2025, 03:42:21 AM
Author Topic: Avanti II . by Robert Baron anybody know this plane  (Read 1838 times)
Offline Chris Edinger
  • Hawker Hurricane
« on: December 09, 2007, 08:15:44 PM »
I am considering building the Avanti II  by Robert Baron.. from plans i've found on the net... does anyone have comments about this design or has anyone built it, flown it.. ???   Im guessing but it appears to be similar to the stiletto...  Thanks...
« Last Edit: December 09, 2007, 09:28:53 PM by Chris Edinger »
Lee's Summit MO
AMA 896082
Offline Bootlegger
Re: Avanti II . by Robert Baron anybody know this plane
« Reply #1 on: December 10, 2007, 04:22:01 AM »
 D>K  Might check with Tom Dixon in the Atlanta area. I think that he and Bob Baron flew together some years ago...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline peabody
« Reply #2 on: December 10, 2007, 05:45:43 AM »
Bob lived with Jim Renkar, PAMPA membership guy, for a while while undergoing treatment...Jim is a great source of information.
Offline Steve Fitton
« Reply #3 on: December 10, 2007, 08:21:09 AM »
My two cents would be to avoid the Avanti like the plague, but thats just my opinion.  I could be wrong.....
I don't know if it's the in line configuration or some other aerodynamic quirk about the design, but both of my Avantis (The Tom Dixon plans for the Avanti 50 and Avanti 60) had handling and trim issues that contributed greately to their major crashes that left both planes obliterated.
It might be noteworthy to consider that Baron won the Nats with a Patternmaster, not an Avanti.
For exhaustive information on the Avanti, check out the "Stabs and the Avanti for Ted" thread in the stunt design section.
Offline Mike Ferguson
« Reply #4 on: December 10, 2007, 08:47:58 AM »
The Avanti II is much, much different than the Avanti 50 and Avanti 60.  They share the same name, but apart from that, they're nothing alike.
The Avanti II is the plane that won the 1981 Team Trials.  Relatively thin wing, thick stab/thin elevator.
Flying Models still has the plans for it: it's in the February 1982 issue.
It's also the exact design that Jim Casale based his 1983 and 1985 Nats winners around.
  • Hawker Hurricane
« Reply #5 on: December 10, 2007, 07:19:49 PM »
Wow... thanks for the information ... it is very helpful... thanks again..
Lee's Summit MO
AMA 896082
