  • June 20, 2025, 11:47:48 PM
Author Topic: Ask Sparky  (Read 9418 times)
Offline RC Storick
Ask Sparky
« on: December 06, 2015, 11:03:26 AM »
« Last Edit: December 08, 2015, 03:22:41 PM by RC Storick »
Re: Ask Sparky $hit
« Reply #1 on: December 07, 2015, 07:52:03 AM »
Why the profanity?
Offline RC Storick
Re: Ask Sparky $hit
« Reply #2 on: December 07, 2015, 08:36:27 AM »
Re: Ask Sparky $hit
« Reply #3 on: December 07, 2015, 09:38:27 AM »
Sparky,
I'm thinking back and I don't remember if you had info on just applying clear cope on balsa prior to attaching covering?
I'm still having some difficulty applying layers of dope on balsa.
Was there a video on that subject?
Charles
Offline Dane Martin
  • heli pilot BHOR
Re: Ask Sparky $hit
« Reply #4 on: December 07, 2015, 09:43:31 AM »
I like this new question and answer videos idea Robert. Thanks man!
Offline Jim Dincau
Re: Ask Sparky $hit
« Reply #5 on: December 07, 2015, 09:44:33 AM »
Is there a current schedule for the live stream both SH and CLC? Also do you start with nitrate and switch to butyrate after primer or use butyrate from the start?
Unless it's crazy, ambitious and delusional, it's not worth our time.
Re: Ask Sparky $hit
« Reply #6 on: December 07, 2015, 10:09:32 AM »
Sparky,
Charles
Your dope is not thin enough.   You want it thin enough to soak into the wood.
Re: Ask Sparky $hit
« Reply #7 on: December 07, 2015, 10:37:41 AM »
Here's a question, do you have to have a hollow prop to win the nats?
Offline Jim Carter
Re: Ask Sparky $hit
« Reply #8 on: December 07, 2015, 12:37:56 PM »
 ;D ;D   Would you rather have all farts be silent but EXTREMELY deadly, or all farts be harmless but EXTREMELY loud?   %^@ %^@
(You said to ask ....! )  LL~ LL~
Offline Doug Moon
Re: Ask Sparky $hit
« Reply #9 on: December 07, 2015, 01:36:22 PM »
Nope.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Re: Ask Sparky $hit
« Reply #10 on: December 07, 2015, 01:40:49 PM »
John,
I reduce the dope 50% with dope thinner.
I still get brush drag.
Charles
Re: Ask Sparky $hit
« Reply #11 on: December 07, 2015, 01:52:37 PM »
John,
Charles
the quantity does not matter, the results do,
if you get drag, you are workig the dope to long, or its not enough thinner
doesnt matter if its 30% or 70 %,, especially since what brand and the age of the dope can come into play,,
Re: Ask Sparky $hit
« Reply #12 on: December 07, 2015, 01:53:59 PM »
John,
Charles
Charles there are a couple of schools of thought (and action) on applying dope to wood structures.  One group (probably the largest) is like Doc and says to thin the dope 50/50 as you do.  The other group says to apply the first two or three coats straight from the can.  I've done it both ways and now subscribe to the latter as being better for adhesion of the covering material.  If you are getting brush drag my first guess is that you are not using enough dope on the brush.  The dope should flow from the brush in strokes from one direction only and as dope drys very quickly (especially with a lot of thinner in it) do not repeatedly brush over the same spot without adding dope to the brush.  It's actually more of a process of flowing the dope onto the surface than brushing it into the surface.  Of course as I'm sure you know, lightly sanding between each coat helps the subsequent coats penetrate better also!
Like you I'm interested in hearing what Sparky has to say about this also!
Offline Mike Griffin
Re: Ask Sparky $hit
« Reply #13 on: December 07, 2015, 03:26:28 PM »
Randy you beat me to it.  I learned a lot about dope finishing a long time ago from Charlie Reeves.  He told me to apply the first coat of nitrate  to the wood airframe straight from the can and I do.  I then put two more coats on after tha thinned 50/50.  I then apply the Polyspan around the edges with thinner only.  He also suggested when using Polyspan on open bays to apply that first coat straight from the can to fill the Polyspan quicker and then follow up with 50/50 subsequent coats.  It is not unusual for me to apply 8-10 coats of 50/50 thinned dope to fill the Polyspan before priming and then color.  Yes brush in one direction only.  I sometimes forget and brush back...I'm human.
Re: Ask Sparky $hit
« Reply #14 on: December 07, 2015, 03:49:14 PM »
Gentlemen,
Thanks for the information.
That's what I forgot, to brush in one directon only.
Thanks again,
Charles
Online Howard Rush
Re: Ask Sparky $hit
« Reply #15 on: December 07, 2015, 04:52:33 PM »
Applies to cats.
Online Howard Rush
Re: Ask Sparky $hit
« Reply #16 on: December 07, 2015, 04:53:31 PM »
Online Howard Rush
Re: Ask Sparky $hit
« Reply #17 on: December 07, 2015, 04:54:19 PM »
Nope.
You might be able to make up for it with enough VGs.
Re: Ask Sparky $hit
« Reply #18 on: December 07, 2015, 05:18:28 PM »
If you can get them all to stay on the wing for a whole flight!   <=
I can tell you that they are effective because funny things happen when they all come off only the inboard wing!   %^@
Re: Ask Sparky $hit
« Reply #19 on: December 07, 2015, 06:09:18 PM »
Re: Ask Sparky $hit
« Reply #20 on: December 07, 2015, 06:10:40 PM »
 Where are we supposed to be to ask questions?
Offline CircuitFlyer
    • www.circuitflyer.com
Re: Ask Sparky $hit
« Reply #21 on: December 07, 2015, 06:55:08 PM »
What works better on cats - nitrate or butyrate?
Paul Emmerson
Re: Ask Sparky $hit
« Reply #22 on: December 07, 2015, 07:37:08 PM »
I think its the VGs
Offline RC Storick
Re: Ask Sparky $hit
« Reply #23 on: December 07, 2015, 07:49:22 PM »
ask here or in youtube video
Offline RC Storick
Re: Ask Sparky $hit
« Reply #24 on: December 07, 2015, 08:55:25 PM »
Re: Ask Sparky $hit
« Reply #25 on: December 07, 2015, 09:31:39 PM »
 A perfectly timed new video here as I'm almost ready to start shooting color on the current project, thanks! y1
 I did use DC540 for the first time on this one and so far I really like the stuff, it dries super fast and sands very nicely. So far this is shaping up to be my smoothest finish ever. As long as I don't have any adhesion issues through the masking and color process I'll be sold, just have to remember to use plenty of thinner. I do wish I would have caught the "tape off the open bays" tip with the primer first though, oh well.
 BTW, when you say 60/40 are you meaning 60% clear or 60% thinner?
Offline RC Storick
Re: Ask Sparky $hit
« Reply #26 on: December 07, 2015, 09:36:03 PM »
A perfectly timed video there as I'm almost ready to start shooting color on the current project, thanks! y1
60% thinner 40% dope
Offline bill bischoff
Re: Ask Sparky $hit
« Reply #27 on: December 07, 2015, 09:40:07 PM »
Applies to cats.
Do you paint ON the cat or WITH the cat? I suppose if done properly, your finish will be the cat's meow.
Re: Ask Sparky $hit
« Reply #28 on: December 07, 2015, 09:41:50 PM »
 That's what I thought, thanks.
Offline Perry Rose
Re: Ask Sparky $hit
« Reply #29 on: December 08, 2015, 04:26:18 AM »
If you paint with the cat, the cat will meow( if you get to close to the bung and if that happens the cat will finish your face) and the finish will be the cat's pajamas.
Offline mike londke
Re: Ask Sparky
« Reply #30 on: December 08, 2015, 05:24:02 PM »
Who makes the DC540 and where can I buy it? Another dumb question but I'm assuming you can put colored dope over this primer? Is it compatible with Sig, Brodak And Randolph?
Offline RC Storick
Re: Ask Sparky
« Reply #31 on: December 08, 2015, 05:54:06 PM »
Sherwin Williams and it's only sold at NAPA auto. You can use any paint over it.
Re: Ask Sparky
« Reply #32 on: December 08, 2015, 06:08:28 PM »
 It comes in a rattle can and DC540 is the NAPA part number. My local NAPA has it right on the shelf. As a note the stuff can be "watery" and run easily if you get in too close while spraying, and also not cover well. Just stay back slightly to be spraying it out somewhat "dry" and it works great. My only real complaint so far is that one can doesn't seem to go very far. When you stop to get some buy at least a couple cans and you might save yourself another trip.
Offline mike londke
Re: Ask Sparky
« Reply #33 on: December 08, 2015, 06:50:49 PM »
Thank you guys. I'll try it out on the next model.
Offline Sean McEntee
Re: Ask Sparky
« Reply #34 on: December 08, 2015, 07:56:43 PM »
Question:
          Since cats always land right side up, and buttered toast always lands upside down, can we combine the two and, using the opposing forces, create enough energy to power everything forever?
Re: Ask Sparky
« Reply #35 on: December 08, 2015, 09:18:49 PM »
Question:
Sure, just figure out how to get the cat inside the toast!  Yes that's the cat inside the toast!
Re: Ask Sparky
« Reply #36 on: December 08, 2015, 09:19:23 PM »
Perhaps;
form a Special Comitte & aply for Government Funding !
DOPE : using sting little on ounce bottles and a weeny brush , or putting on with a dryish brush anyway
as opposed to ' loading ' a brush and slopping on & brushing out - so 4 or 5 wettings with a 1 1/4 wide
x 2 in long brush do a sheet of 3 x 36 in , are differant .Weve Found .
Doing it like our painting say a window frame with house paint rather than ' just ' covering the wood with minimum Qty
seem to affect the Bond.
Offline rich gorrill
Re: Ask Sparky
« Reply #37 on: December 09, 2015, 06:56:24 AM »
Hi Sparky, how about a short video on fillets. I'm not sure if you covered this on another post. What makes the best fillets, how do you apply and finish them? what product is easiest to sand?
Rich
Offline Rick Bollinger
  • AMA 931589
Re: Ask Sparky
« Reply #38 on: December 09, 2015, 09:43:43 PM »
Read about polyspan tried it on my last project and gave up and used silkspan instead. Going to try it again on my vector. I have 3 nice coats of Randolph Non Taughtning on the framework. Do I need to use Taughtning over the bays after shrinking to keep it tight or the heat alone and use the non taughtning. Thanks Rick
Rick Bollinger
AMA 931589
Re: Ask Sparky
« Reply #39 on: December 09, 2015, 09:49:58 PM »
 Rick,
 Polyspan can be a little tricky if you're not used to it. Be patient though and work carefully and once you get the hang of it you'll never go back. As far as the dope goes I've always used taughtening all the way through from start to finish. I've never felt the need to use non-taughtening on anything, anytime, ever.
Re: Ask Sparky
« Reply #40 on: December 10, 2015, 10:02:53 AM »
I agree with Wayne.  Use taughtning from start to color coats.
  • AMA 931589
Re: Ask Sparky
« Reply #41 on: December 10, 2015, 08:15:21 PM »
Wow ok will use it the rest of the way. I always have with silkspan but I figured with polyspan non taughtning was the way to go.
Rick Bollinger
AMA 931589
