  • July 03, 2025, 05:04:10 PM
Author Topic: ENYA's new CL motor  (Read 892 times)
ENYA's new CL motor
« on: February 25, 2008, 12:41:38 PM »
Hello
a NEW Stunt engine is now finished
Enya has finished the 53 4 Stroke stunt engine, specs are:.........
1. 53-4C S PRO. (for Control Line)
Bore x Stroke 24.0 x 19.2 (mm)
Displacement 8.69 (cc)
Weight 415g (with muffler)
Construction 4Ball Bearing, OHV, double camshaft, 4 stroke cycle model
Revo. Range 7,000 ~ 12,000 (rpm)
Propeller size D 11.5 ~ 13 x P8 ~ 6
straight muffler M534CS (34g), safety plug code SP-1
with muffler
2. 534C29 CL conversion kit for 53-4C (41-4C) 534C29
Venturi size 7mm and 7.3mm
Needle valve 534C20 special needle valve set
Venturi adaptor Set to intake of the venturi body (2g)
Weight 22g (with venturi adaptor)
and Yes ENYA has a kit to convert your R|C ENYA 53 to a CL venturie setup
