Does a fair breeze at your back, say 7-10 mph eliminate wake turbulence?
I was doing consecutive 8s with my Shoestring yesterday with a good breeze. I don't remember the lines ever feeling light, but when I watched the video, I saw that I was taking a step back on each loop. I didn't even know I did it until I saw the video evidence.
The breeze would easily take care of it if it was really 7-10 mph, but people often overestimate wind speed. For mere mortals, 12 mph is a LOT to fly in, whether F1A or F2B. Many will say that a 12mph breeze is a 20 mph gale. I would speculate that if the model looked like it was hitting wake turbulence, you were actually hammering the controls too hard on corners, or making the round tricks too small, stalling the wing or tail to some degree. Avoid that! Flying 25' "bottoms" and 45 deg. "tops" is asking too much of the airplane.
When you get more comfortable with doing the tricks, start concentrating on what you do with your feet, before and during the trick. For example, moving your feet in the OH8 is NOT what you want to do (Attn: Rex Abbot). You really don't WANT to move your feet during any of the tricks, BUT when you do any consecutive maneuvers (except the OH8, obviously), you need to beware of wake turbulence when the wind is calm. When the wind picks up to where it accelerates the model and makes the line tension increase, you'll need to practise positioning yourself at the upwind side of the pilot's circle at the start of the trick and then following it downwind as the trick unfolds, to reduce line tension and reduce model's speed buildup. This is an important pilot skill, and I'm working on mine. In the OH8, you can start at full height, arm extended, and do the 2nd OH8 a bit crouched with arm less extended, to give your plane "cleaner air". There are a lot of flying tips in the Judging Clinic Forum, if you care to read up. Tho that really isn't the intent of the forum, it just seems to happen and is also helpful for those learning to be judgemental!
One day, you'll find that your plane has excellent line tension in the OH8 on one flight and very little line tension on another flight. That there is the difference between a "thermal" and a "downdraft". As the breeze blows, the "lull" marks the downwind side of the thermal as it comes to you, and the stronger than normal breeze following the lull is the "infill". A thermal is a miniature twister or dust devil, which is in turn a miniature tornado. I've seen lawn chairs 50' in the air at free flight contests in California! Not good!
Edit: Flying on a pilot's circle that isn't flat and smooth makes all this stuff a lot harder...grass any worse than a soccer field is really tough, and tiring.
