  • July 18, 2025, 12:52:52 AM
Author Topic: DC540 replacement  (Read 1961 times)
Offline Ty Marcucci
DC540 replacement
« on: August 18, 2021, 03:02:22 PM »
Has anyone found a good replacement for DC540?
« Last Edit: May 27, 2022, 11:42:28 AM by Ty Marcucci »
Ty Marcucci
Offline Matt Colan
Re: DC540 replacement
« Reply #1 on: August 18, 2021, 03:20:13 PM »
Check out the harbor freight auto primer. I had pretty good luck with it and sanded like the old DC540 when I used it
https://www.harborfreight.com/10-oz-gray-sandable-primer-spray-paint-60789.html
« Reply #2 on: August 18, 2021, 05:04:36 PM »
Good old DC540 havent used that in years.
« Reply #3 on: August 18, 2021, 11:41:32 PM »
Has anyone found a good replacement for DC540?  I know about making my own primer, but that stuff really did the job, and I find I am getting more lazy.  Might just be the heat and humidity. H^^
  You mean this?:
https://www.napaonline.com/en/p/DC_DC540
   It looks like it is available.
    I use KlassKote white primer - I am pretty sure it will be compatible with any model paints.
Offline gene poremba
« Reply #4 on: August 19, 2021, 04:05:19 AM »
 while the NAPA DC-540 is still available, the formula has been changed for the bad. I have been using a product Robert tried and it works as well or better than the old DC-540. Its called CREST Hi Build primer GRAY STK# AH-BG. It sprays on nice and dries quickly. It sands off to a nice powder. I buy it on line. I have only used it over butyrate clear and under butyrate Brodak and Randolph colors. After half a dozen models i have had no problems. Its not cheap, but convenient to just grab the can when i need to use primer......Gene
Offline Matt Colan
« Reply #5 on: August 19, 2021, 06:53:15 AM »
D>K
Hows does it react with Brodak or Randolph dope??
I had good luck spraying both over the top of it with no issues. The harbor freight stuff works well, but zinc stearate is a far superior product in my experience
Offline Tom Luciano
« Reply #6 on: August 19, 2021, 12:48:03 PM »
Ty,
  Al Ferraro found this stuff. It's about as close as you can get to DC 540. It actually builds up faster. Sparky has tried it and felt it was a good substitute as well.
 Al is a professional autobody guy and has access to it. You have to see if you can get it as it sold to more/less body shops only.
https://crestauto.com/shop/primer/aerosol-primer-aids/hi-build-gray/
Tom
AMA 13001
« Reply #7 on: August 19, 2021, 02:28:28 PM »
Thanks Matt and Tom. I now have 2 cans of each to try out. Got snake bit when I bought 12 of the DC 540, only to find it was not what I had been using.  H^^
Don't by shy, Ty! Take that crap back and tell them why, Ty! Let us know what works best, or try, Ty!  LL~ Steve
Offline frank williams
« Reply #8 on: August 19, 2021, 04:05:38 PM »
It looks like the Harbor Freight stuff is 1/3 the cost of the other.
