  • July 19, 2025, 07:38:27 AM
Author Topic: Brodak Cosmic wind.  (Read 4755 times)
Offline Andrew Saunders
  • 2013 Nats
Brodak Cosmic wind.
« on: July 14, 2013, 06:42:37 PM »
Today after flying in the Beginner NATS i recieved the Brodak Cosmic Wind. Does anyone know anything about this plane? Anh changes need to be made? I am gonna buiild it for my nephew .
Offline Phil Spillman
Re: Brodak Cosmic wind.
« Reply #1 on: July 14, 2013, 08:11:25 PM »
This is in all likelyhood an updated version fo the old Goldberg version. Build it as suggested and have a ball flying with it as is. With the "new" .25 engines now available I'll just bet that this will be a better performer than it ever was with the venreable engines when it first came out!
Phil Spillman
« Reply #2 on: July 15, 2013, 02:38:16 PM »
This kit is an updated version of the Goldberg kit of the '60s.  Slight changes in construction such as a multiple piece LE instead of the old shaped solid piece.  Brodak also sells updated Goldberg kits of the Shoestring and Buster.  These were all really good flying "sport" profiles and the Brodak kits allow a little lighter building due to better wood and such.
Using an OS .25LA or Brodak .25 is perfect for these.
BIG Bear
RNMM/AMM
  • 2013 Nats
« Reply #3 on: July 15, 2013, 05:52:35 PM »
On the opposite side of the fuselage is the nose piece that goes over the plywood doubler. My nephew may not like to have that on there. Would it hurt anything such as how the plane flys to not have it on there?
Offline Geoff Goodworth
« Reply #4 on: July 15, 2013, 06:06:38 PM »
Andrew, the cheek cowl is a representation of the engine cowling on the real aircraft. I would not delete it because I believe that it helps to strength the nose and damp vibration.
  • 2013 Nats
« Reply #5 on: July 15, 2013, 06:49:47 PM »
OK!! That i completely understand.
« Reply #6 on: July 16, 2013, 08:02:17 AM »
As stated, build the kit box stock.  It should fly as well as or better than the Goldberg version.
« Reply #7 on: July 16, 2013, 10:28:54 AM »
If you would really like to make this plane strong so that it doesn't vibrate nearly as much as it might...utilize leather fillets all around the wing fuselage joint! Soak these for 15 min. in water and then apply with aliphatic glue and pins. Let dry for a few days and you'll have one really strong profile plane!
Phil Spillman
  • 2013 Nats
« Reply #8 on: July 17, 2013, 07:05:00 PM »
Started building the Cosmic wind today. Got the motor mounts, ply doublers, and the canpy all glued on the fuselage and the ribs are on the wing jig. Tomorrow i start adding spars and fully laying out the wing. My Nephew will like this plane.
  • 2013 Nats
« Reply #9 on: July 18, 2013, 07:23:06 PM »
Started building the wing today. Got it in the wing jig and probably another two hours of work and the wing will be done. So far an easy kit to build.
« Reply #10 on: July 19, 2013, 07:54:24 AM »
I've lost count how many of the Goldberg kits I have built and finished.   I know at least six Shoestrings at one building session.   The only wing that did not come out straight was the very first Shoestring I built when they first came out.   Used the jig tabs and all.   After that one all the rest were built in  my lap using pins and tape plus CA.   On the elevator, if they still show just the plywood plate for a joiner, use it with another on the other side of the elevator.   I usually make it big enough to mount the control horn.
  • 2013 Nats
« Reply #11 on: July 19, 2013, 06:56:16 PM »
Right  now im stuck!!!!   I need to decide what engine to use on this plane. Its gonna be for my nephew who will be flying with a trainer to start out with. Its gonna be used for stunt. Should i run a .35 or a .25? With the cheek cowl it seems a little heavy. But i need to make this decision on what engine to make before i go any further and then talk to my brother and sister in law about purchasing the engine. Any suggestions would be great on this engine choice.
  • 2013 Nats
« Reply #12 on: July 19, 2013, 06:57:23 PM »
Im also looking at the Super Tiger G-34.
Offline Dennis Moritz
« Reply #13 on: July 19, 2013, 08:12:13 PM »
LA25.
« Reply #14 on: July 19, 2013, 08:33:45 PM »
A Fox 35 would work OK, but the LA 25 is pretty much the perfect match!
I would change the needle valve to an ST or PA style for either one.
Mike Griffin
« Reply #15 on: July 19, 2013, 09:41:40 PM »
LA .25 Andrew.  Great little engine...
« Reply #16 on: July 19, 2013, 10:15:30 PM »
 LA .25 would be good, just watch the weight of the build. y1
Offline Peter Grabenstein
« Reply #17 on: July 19, 2013, 10:18:12 PM »
Carbon fiber pushrod and 2 glass fiber sheet doublers instead of plywood works GREAT on my C.G. Shoestring.
Not to forget Alu tabs between engine lugs and fuse for solid mounting  H^^
« Last Edit: July 21, 2013, 10:31:34 PM by peter grabenstein »
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
« Reply #18 on: July 20, 2013, 09:00:45 AM »
Got to go along with the LA .25 on this model.  Super easy to run, and consistent.
The Enya .25 and .30 that are current would be good choices, too.
BIG Bear
RNMM/AMM
Offline Balsa Butcher
  • High Desert Flier
« Reply #19 on: July 20, 2013, 09:48:56 AM »
OS-35S if you can find a good one. LA-25 and OS-35S for sale over on the other forum. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #20 on: July 20, 2013, 10:24:34 AM »
Even tho I am a Fox man,  go with the LA25.   Runs great straight out of the box if you don't push it.   Just lean enough to get airborn with 10-4 or 9-5 prop.   Besides a rich setting will be slow enough that he may not get the dizzies.   Another thing is just enough fuel for about 20-25 laps.
  • 2013 Nats
« Reply #21 on: July 21, 2013, 06:19:30 PM »
Well made my decision. I have a fox 35. stunt 50th anniversary that i used on a ringmaster and works great!! No burping issues at all and has a nice break to it. The reason for using this engine is because money is tight and i have the engine and it will work on the plane. I took the cheek cowl and ported it to push air to the back of the engine to help add a little cooling back there. The wing is ready for controls but i am in the middle of deciding of weather or not to use carbon fiber pushrod or the pushrod supplied with the kit. This is my first build aFTER MIKE s taught me to build. im getting jealous of my nephews plane. Its turning out great. But i promised it to him and so its his. He plays for the Marysville patriots and wanted the color scheme to  match the patriots colors so i need to find the patriot head to stick on the canopy and go from there.
« Reply #22 on: July 22, 2013, 08:19:46 AM »
If you go with the music wire pushrod, don't forget to put a fairlead, I use a cotter pin, about half way along the push rod.   Will have to go look on the plans, but I think they show it.
Mike Griffin
« Reply #23 on: July 22, 2013, 08:34:24 AM »
Andrew I dont know if the Cosmic Wind is still available in kit form or not but if you ever want another one RSM kits a MISS SARAH and it is the design is the Cosmic Wind.  I built and flew two of them ....
« Reply #24 on: July 22, 2013, 08:49:20 AM »
Brodak has a kit according to his site.  Also you can get full size plans,  laser cut ribs and some other stuff.   Sorry Mike just another option.
Offline Mike Lauerman
« Reply #25 on: July 22, 2013, 08:55:58 AM »
Hi, Andrew. Porting the cheek cowl is a great move! Its existence stiffens up the nose effectively, but porting lightens it up AND directs air to flow past the crankcase, where there's a 'dead zone' of hot air when the left doubler is closed off...
