  • August 01, 2025, 07:38:49 PM
Author Topic: Dave Brown Lite Flite wheels?  (Read 1830 times)
« on: July 14, 2014, 02:39:22 PM »
I see the Dave Brown Lite Flite wheels, 2.5" weigh .5 oz each.
Thay are made of foam, so do they hold up? To spongy?
Thanks in advance.
Charles
Offline ericrule
Re: Dave Brown Lite Flite wheels?
« Reply #1 on: July 14, 2014, 03:34:13 PM »
In my opinion they are the best wheels on the market. The tire portion does not come off the axle unlike many of the other brands. I would always order the treaded design. If you are looking for a narrow wheel to fit inside wheel pants they are available in 1-3/4, 2 & 2-1/4" sizes. The standard width wheel come in 1-1/2 through 6" sizes.
Eric Rule
« Reply #2 on: July 14, 2014, 05:38:58 PM »
Wide for grass, narrow for pavement. I like the slicks for either grass or pavement. Good stuff, they bounce much less than some (Great Planes/Hobbico) products, and relatively affordable, considering they're 'made in USA'.  H^^ Steve
« Reply #3 on: July 14, 2014, 05:52:22 PM »
Well gentleman thanks for that advice.
I'll take it!
And take it I did. #^
I ordered 2.5" wheels for the P-40.
Flew it with the 2.25" wheels it came with off cut grass, so the 2.5" isn't a serious improvment, but will look  better.
The Old Gal with new shoes.
Thanks for the reply!
Charles
Charles
« Reply #4 on: July 14, 2014, 09:38:42 PM »
I basically agree with what was said above.  However I would mention that with big airplanes on asphalt (like I fly here in Tucson), they do wear out pretty fast!  If they're in wheel pants make them replaceable!
Personally I prefer the DuBro Lite Wheels.  They last a lot longer (they are a little bit heavier).
« Reply #5 on: July 15, 2014, 01:25:59 PM »
If they wear out, it's because I'm dragging the model sideways to slow/stop it at the best place for my pit guy to pick it up. I really need to figure out a good adjustable braking system that will work with wheel trousers...if only I was a retired Engineer, and not a retired Machinist. I'm thinking  of a micro-screw adjustment scheme. Any ideas, Randy? My ex-Whittle "Eagle" uses these for axles on a Winship CF LG. Top of the page...the screw that mounts these is about a 4-40...at least, it is now. Top of the page! I like 'um... All the rest are gawdawful heavy!  y1 Steve
http://www.centralhobbies.com/landing_gear/axles.html
« Reply #6 on: July 15, 2014, 04:12:39 PM »
I can say I really like the wheels I got from Stunthanger Hobbies. The aluminum rim wheels are awesome. I ordered the 2.5" jobs then turned the tires down to about 2". Sort of a big wheel, low profile tire look.
