General control line discussion => Open Forum => Topic started by: Motorman on June 30, 2014, 10:34:07 AM
I had this package of Dave Brown CF ribbon for years and finally thought I would try it and wow really nice stuff. Had to be careful handling it because it has no sizing to hold it together but it wets out and fills the mould so easy. They only sell it in 12' so I thought I would ask if anyone knows where you can get a bigger roll of loose CF tow 3/4 wide with no epoxy sizing.
MM
try www.cstsales.com
Thanks Bob. I see from 3k to 50k which do you think is about 3/4", what do you use?
MM
sounds like 50 K thats what i use for my props
Bob, you ever have props come out of the same mould and be different pitch? I made one with Dave Brown carbon and one with Perkins stuff and the first one was less load on the test stand. Maybe the mould squeezed the fibers a certain way and created stress? Both times I had too much fiber stuffed in there.
MM
