  • July 07, 2025, 01:57:23 PM
Author Topic: Cya "plastic" hinges to hinge 1/2A Ambush models for my 8 kids  (Read 2954 times)
Offline Allen Brickhaus
  • ACE
« on: October 07, 2013, 08:21:52 PM »
I am looking to purchase a set of those single flat hinges that will slip into a small slit in 1/8" wood and are glued in with thin Cya glue.  This will be used to hinge 8 X 1/2A Ambush models for my Patton Street Pirate Pilots.
Offline mike londke
Re: Cya "plastic" hinges to hinge 1/2A Ambush models for my 8 kids
« Reply #1 on: October 07, 2013, 08:35:37 PM »
Allen,  IMHO those hinges are too stiff for 1/2a. I have tried them and had trouble. I use cloth hinges applied with dope or Sigment. Most recently I tried some of Tom Morris's dacron hinge material and was very impressed. It will be my go to hinge on all sheet elevators from now on.  You could always go old school and stitch the elevator.  Good luck, I think it's great what you are doing for those kids.  Mike
« Reply #2 on: October 07, 2013, 08:49:39 PM »
2nd vote for stitch.  Maybe not what you want to hear, but...
If you just can't stand that thought, and if they're painted, what about Scotch tape?  It should be floppy enough, it's easy and quick, and the hinge line sealing task takes care of itself.
Offline bob whitney
« Reply #3 on: October 07, 2013, 09:34:47 PM »
Allen if u allready have the hinges cut a notch on each side so u are only using about 1/3 of the hing ,it will still be plenty string enough  stiching works good and easy to replace
rad racer
Offline Mike Keville
« Reply #4 on: October 07, 2013, 10:55:48 PM »
Little too early for an April Fool joke?
« Reply #5 on: October 08, 2013, 10:35:17 AM »
   Hey Allen;
    Review the procedure for installing the hinges in the elevator of the SIG P-Force if you have the instruction booklet. They describe making cut-outs like Bob Whitney mentions also, that cut down the area of the portion that bends. I think I took a toothpick and rubbed a little Vasoline right at the hinge line also, and that kept the CA glue from creeping into the hinge area and making them stiff. They lasted for 6 years or so until I recovered the airplane and I cut them out. They were beginning to delaminate by this time, but should last long enough for your purposes.
  • ACE
« Reply #6 on: October 08, 2013, 02:39:00 PM »
Probably will not need them for more than six flights apiece.
Online Paul Taylor
« Reply #7 on: October 08, 2013, 03:38:20 PM »
Dental floss the wide stuff works great. Baseball stitch!
Easy to get and only a drop of ca on the end knot.
Offline dale gleason
« Reply #8 on: October 08, 2013, 03:41:51 PM »
I've got some of those, I think. If I find them, they're on their way, For half/A, just cut them into strips, no brainer.
dale g
Edit: No luck, just went through a whole lot of stuff and no joy, sorry, Allen.
« Last Edit: October 08, 2013, 04:02:30 PM by dale gleason »
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #9 on: October 12, 2013, 06:16:16 PM »
packing tape will work great
Dave Siegler
NE9N extra class
AMA 720731
  • ACE
« Reply #10 on: October 14, 2013, 07:20:00 AM »
All of you are great help.  I appreciate the Internet help.
Allen
Offline Duke.Johnson
« Reply #11 on: October 14, 2013, 08:24:22 AM »
I use those hinges all the time.  I just cut them down to keep them from being stiff.  About an 1/4" wide for 1/2a.
