CLICK HERE--><--CLICK HERE
Tail Wheel preferences?
Started by Brent Williams, September 06, 2026, 07:45:09 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Brent Williams
What are you guys using, (that is currently available,) for the tail wheel on your planes?
A quick search indicates the DuBro 75TW 3/4" Tailwheel and the lighter 1" foam 100MW Mini Lite Wheel are pretty easy to source.
There are some interesting 16mm and 20mm wheel selections on AliExpress.  Any other tailwheel choices I should start to hoard?
Reptoid
       Don
       AMA # 3882
Perry Rose
Wheels from a plastic model kit.
Ken Culbertson
Quote from: Brent Williams on September 06, 2026, 07:45:09 PMThere are some interesting 16mm and 20mm wheel selections on AliExpress.  Any other tailwheel choices I should start to hoard?
I stopped using those, both main and tail, because they melt and form flat spots on a Texas asphalt circle.  They narrow ones (main tires) also throw the tire from the rim allot if you don't CA them in place.
Tim Wescott
Years ago I cruised Goodwill and found a semi tractor toy that had 1/2-in wheels on it. Nice rubber tires. I can either drill proper sized holes in the wheels and use them as is, or I can turn aluminum hubs which is about the right speed for my machining capabilities.
I'm still working through those.
If your notion of "currently available" stretches to flea Bay, there's probably a lot of new old stock tail wheels on there if you dig.
Dave_Trible
Sullivan still has nice tail wheels and are a little lighter and narrower than Dubro which is also fine.
Quote from: Dave_Trible on September 08, 2026, 06:46:23 AMSullivan still has nice tail wheels and are a little lighter and narrower than Dubro which is also fine.
    I haven't checked their website for wheels yet, but they have cut back on a lot of other stuff since they were bought out about a year ago. Their line of fuel tanks is greatly reduced.
Dan Berry
Use the square wheel instead of the triangular wheel.
One less bump per revolution.
Optimistic Optimistic x 1 View List
Lauri Malila
Quote from: Brent Williams on September 06, 2026, 07:45:09 PMWhat are you guys using, (that is currently available,) for the tail wheel on your planes?
Williams bros Smooth contour 3/4" is nice.
Don't know if the company still exists, but Ebay has them for sure. L
Brett Buck
Quote from: Reptoid on September 07, 2026, 01:09:51 AMThis one works well for me
https://www.amainhobbies.com/sullivan-tail-wheel-3-4-sul351/p117691
  Those are the ones I use. We drill out the hole so that you can press-fit the 1/2A silicone tubing as the bearing. That makes it almost silent when it rolls.
fred cesquim
sullyvan design is great but the rubber cracks shortly ( had more than 20 cracked )
du-bro lasts decades
