  • June 23, 2025, 01:12:24 PM
Author Topic: 1st flight on CardinalARC  (Read 1920 times)
Offline Ralph Wenzel (d)
« on: December 24, 2006, 02:44:38 AM »
Friday, off grass. CardinalARC @45 oz., with Saito .40, 11-5 APC scimitar (make that "finger guillotine"), tuned by ear (tach battery dead). Absolutely unbelievable power!
Flew forever on a 3 oz. tank of PowerMaster 20-20, with huge line tension. Enough that my hand/arm were completely exhausted following the single flight. Guesstimated 5 lb. line tension overhead; at least double that in level flight, with no engine or rudder offset. I have never had a plane with such outstanding line tension everywhere!
First trim adjustments will be reset elevator a bit (turns much tighter outsides), then some tailweight, then longer lines. Then ? ? ?
Ralph Wenzel
AMA 495785 League City, TX
Offline Manuel Cortes
Re: 1st flight on CardinalARC
« Reply #1 on: December 24, 2006, 02:58:42 AM »
Congratulations, nice plane!!!
My 46 oz ARF Cardinal is powered by a plain bearing Stalker 46, very sweet combo, won his first contest last Sept in Madrid  #^. Against Yatsenko Stunters, piped stuff..... the Cardinal didnīt miss a beat!!!!!
Later will go a Tigre 46 just for comparing with the Ukranian in the air.
MERRY CHRISTMAS ALL!!!!!!! ~>
Regards from Spain.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: December 24, 2006, 06:44:38 AM »
Ralph, might be beating a dead horse but if your Saito is a 40a and you haven't already, please read this whole thread...
http://www.egpworld.com/forum/default.aspx?f=2&m=19040
It was quite an education for me on the Saito 40 and props...
Built a Cardinal ARF to use as a ST 46 test bed.. Great combination once I got the Cardinal flight trimmed.
« Reply #3 on: December 25, 2006, 01:57:51 AM »
Thanks, Bob. I believe I read this thread some time ago, but there is so much info that I can't assimilate all of it in one reading, nor in two of three flying sessions. As I mentioned, this was my first (successful) flight with a 4-stroke.
I did buy an APC 11-6 and 11-7, and will try them next week, just to see. And the tach will have a fresh battery, too!
Ralph Wenzel
Offline Bob Reeves
« Reply #4 on: December 25, 2006, 06:22:15 AM »
Ya that thread does cover allot of ground but it really goes through the whole process from almost giving up on 4 strokes to having one of the best engines I have ever flown. Good luck and Merry Christmas..
Offline Richard Grogan
« Reply #5 on: December 25, 2006, 09:57:55 AM »
Way to go Ralph! Glad to hear you got a dependable run on that thingy...
Long Live the CL Crowd!
                  AMA 85745
« Reply #6 on: December 25, 2006, 11:33:59 AM »
HI Ralph,
It's a great feeling when an airplane comes out the way we like!  May it give you thousands of great performances.  y1
Wishing you the Happiest of New Years!
Bill <><
Offline Bob Reeves
« Reply #7 on: December 26, 2006, 08:49:11 AM »
It's not the airplane it's that hunk of aluminum and steel you hung on the nose  **)
