  • June 18, 2025, 08:07:50 AM
Author Topic: Kit Survey for Ringmaster Sportster  (Read 2422 times)
Offline pat king
    • PDK LLC
« on: August 29, 2010, 05:53:30 PM »
I have just shipped the prototype kit out to have it built. I will be offering laser cut short kits, with or without the machined leading edge. The plans show how to make the leading edge. The kits will include 3 sheets of 36 x 48 full size plans. The plans have all parts full size. I will also offer plans or electronic files of the plans. The short kits will be in the $95 to $100.00 range. let me know if you think you want one, I'll let you know when I am ready to start selling the kits.
Thanks, Pat
These items are not included in the kit:
4 pcs.       1/16 X 1 ½ X 24 Balsa
3 pcs       1/16 X 3 X 24 Balsa
2 pcs.      3/32 X ¼ X 42 Balsa
1 pc.      1/8 X 3 X 36 Balsa
2 pcs.      3/16 Sq. X 36 Balsa
2 pcs.      3/8 X ½ X 7 Hardwood
1 pc.      1/8 X 36 Music wire
1 pc.      3/32 X 24 Music wire
2 ea.      2 ½” wheels
1 ea.       2” wheel
4 ea.       DuBro 1/8” landing gear straps
1 ea.      3” Bellcrank
1 ea.      1/8” Elevator horn
1 ea.      Elevator horn
1 ea.      Canopy
The landing gear will have to be formed from the 1/8" wire, the plans have full scale templates. The canopies are available from Bill Sawyer.
« Last Edit: August 31, 2010, 10:56:09 AM by pat king »
Pat King
Monee, IL
AMA 168941
Re: Kit Survey for Ringmaster Sportster
« Reply #1 on: August 29, 2010, 06:31:59 PM »
 Who does the decals? Vinyl or waterslide?
Offline pat king
    • PDK LLC
« Reply #2 on: August 29, 2010, 08:26:34 PM »
I do the decals. They are waterslide, printed on an inkjet printer and fixed with clear Acrylic. I scanned the original and then spent over 8 hours touching it up to get a good clean decal.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #3 on: August 29, 2010, 11:27:43 PM »
I want one. PM sent.
« Reply #4 on: August 30, 2010, 12:58:54 AM »
 Thanks for the decal info Pat. I'm going to need to figure out a way to get a replica "Super Combat Streak" wing decal made for the kit I just got from Walter Umland recently.
Offline pat king
    • PDK LLC
« Reply #5 on: August 30, 2010, 07:07:17 AM »
Wayne,
The decal material is from "Micro Mark". It makes nice decals. That is how I make the decals that I include in the Baby Ringmaster kits.
Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #6 on: August 31, 2010, 10:57:52 AM »
I have added a list of things the kit does not contain. H^^
Pat
Pat King
Monee, IL
AMA 168941
Offline dennis lipsett
« Reply #7 on: August 31, 2010, 04:06:47 PM »
I'm almost certain that the Super Combat streak did not have a decal.
Dennis
« Reply #8 on: August 31, 2010, 06:04:40 PM »
 Mine will. ;D
Offline Jim Pruitt
« Reply #9 on: October 24, 2010, 01:31:08 PM »
Pat,
where is your web site?  I would be interested in the electronic plans.
Thank you.
Jim Pruitt
Offline Garf
    • Hangar Flying
« Reply #10 on: October 24, 2010, 06:23:12 PM »
I'm interested in the plans, but I'm not sure about the electronic plans. Do they print out at the proper size?
Offline Jerry Leuty
« Reply #11 on: October 24, 2010, 07:58:55 PM »
I remember this kit from the 60s. I have never seen one in person. Is it for a .35? I finally did see a Ring Master Imperial hanging in Central Hobbies in Albuquerque. Jim Snelson's shop. What is the wingspan and numbers.................Jerry
« Reply #12 on: October 25, 2010, 01:01:14 PM »
Just enlarge the plan and look in the lower right corner.   VD~
Offline pat king
    • PDK LLC
« Reply #13 on: October 27, 2010, 11:13:45 AM »
I do not have a web site. The wingspan is 38", it has 307 square inches. It is good for a .35, a modern .25, or a modern .20 . The electronic plans are full scale .tif files at 200 dots per inch. They will print out full size. The plans shown above have been reduced in size and density to display here.  H^^
Pat
Pat King
Monee, IL
AMA 168941
