  • July 11, 2025, 11:21:49 PM
Author Topic: Wheels for wheelpants  (Read 1691 times)
Offline Bill Sawyer
« on: December 09, 2010, 06:51:42 PM »
I have been looking for a source for narrow wheels to fit inside wheel pants. I have wanted to make the width of my wheel pants narrower. There are some 2 inch foam wheels ( Dave Brown if I remember correctly ) that are only 1/2 inch wide but they wear out on hard surfaes and will flatten if the plane is left sitting on the wheels. I installed access panels in the wheel pants but I didn't like those so I changed to the Hangar 9 wheels. Yes they were wider but by putting them on my belt sander and removing all the tire rubber down even with the wheel rim they got fairly narrow. A little Sharpie ink to change the dull finish back to black and they were fairly acceptable. After removing a lot of skin and fingernails, I figured there had to be a better method. Better yet there is possibly some secret brand of wheel I have not heard of. So whats the way everyone else is doing it?
Bill Sawyer
AMA 53987
Windancer Models
Offline Balsa Butcher
  • High Desert Flier
Re: Wheels for wheelpants
« Reply #1 on: December 09, 2010, 08:05:22 PM »
Bill: Mark Warashana (I probably spelled that wrong) supplies narrow racing wheels for the racing and carrier community. I bought mine through Wayne Buran, but Mark advertises in "Flying Lines", which is the excellent on-line newsletter for the Northwest Region Control line clubs. They are very narrow/streamlined, of the highest quality and wear well. Check it out.  8)
« Last Edit: December 10, 2010, 08:47:10 AM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
Offline Rudy Taube
  • Ret Flyboy
« Reply #2 on: December 09, 2010, 08:47:54 PM »
Bill,
These may be good for your narrow wheel pants. I have them on several airplanes. They are very light, strong enough, and very narrow. And inexpensive.  :) Your LHS should have them.
            http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTDS7&P=ML
They come in several (Dia.) sizes.
« Last Edit: December 10, 2010, 12:38:21 PM by Rudy Taube »
Rudy
AMA 1667
« Reply #3 on: December 09, 2010, 09:14:49 PM »
Rudy,
I've used these but they wear out pretty quickly. At least for me.
« Reply #4 on: December 09, 2010, 10:24:42 PM »
Rudy,
   Me too, but they are cheap and you want to make provision for replacing them, anyway. I generally replace my wheels (Dave Brown or these kind) just before the NATs every year.
Offline Mike Haverly
« Reply #5 on: December 09, 2010, 11:09:57 PM »
I used these on my new classic model.  I had to bush them to get a good fit on the axle and roll straight.
Offline Rudy Taube
  • Ret Flyboy
« Reply #6 on: December 10, 2010, 03:09:56 AM »
Rudy,
Hi Randy,
Good point. I forgot to mention that I fly 98% off of grass. Like Mike said, putting a brass bushing on them would be a good idea on pavement where they roll a lot longer and faster. I don't know how well the tire will hold up if someone flies mostly off of pavement?
Rudy
AMA 1667
Offline Mike Lauerman
« Reply #7 on: December 10, 2010, 09:09:31 AM »
We used to use racing wheels to get them to fit inside the narrow wheel pants. There is a source that was mentioned on here, but I can't find it.  H^^Luckily I still have three sets of them. Two installed on my Cobra and on an Ares.
type in "racing wheels " in the search box. Lots of info there.
Racing wheels work well, except for the 'knife-edge' tread look. I used some oversized ones, (3") chucked them in my electric die grinder, and took off 1/4" on the belt sander, shaping them as I went. Looked good.
For my Golden Age stuff, (Gee Bees, Mystery Ship, etc.) I use Williams Bros. 'Golden Age', as they are scale spokes with simulated fabric covering. They allow a narrow, scale pant.
That said, the Mystery Ship has pants big enough to be worn by Homies! (these would allow a wider tire...but I still used the Wms. Bros. Golden Age type, bushed with brass)
« Reply #8 on: December 10, 2010, 09:32:56 AM »
I like the idea of the "take apart" wheel pants best of all, and I have done it several times.  Of course, my Geo Juno is about 13-14 years old and on its original Dave Brown Lite Flites.
I have several sets of the old Veco "Grasscutters" (1 7/8" streamlines) that I use on my old I-Beamers.  They are fairly hard solid rubber, but even those will wear down on pavement.  Thankfully (in some regards) I only have grass fields to fly off of around here which really cuts down on wear.
Big Bear
« Reply #9 on: December 10, 2010, 01:22:11 PM »
Bill, what size wheels are you looking for diameter wise?   I have some Glenn Lee wheels that are made for racing that I use in some of my stunt planes.  They are a very hard material he molds around the hub.  They are in color also.  depending on the size I have. H^^
Offline Jim Mitchell
« Reply #10 on: December 12, 2010, 04:28:27 AM »
There was a wheel that was called DON'S wheels   i think les Mcdonald used them on his Stilleto. they would be what you need.   Jim
Offline Allen Brickhaus
  • ACE
« Reply #11 on: December 12, 2010, 06:45:46 AM »
When resizing foam type wheels, put the entire wheel assembly in the freezer,  they seem to shape better when frozen.
Allen Brickhaus
