Alternate idea...I've always thought that a 2-piece wing arrangment (like Tom Morris') would be especially good on a
profile fuselage. You wouldn't have to cut a big hole for the wing, just three small holes for the connectors (Tom Morris-type...which is very much like Lauri's TE joiner, times three, one for each spar (top & bottom assumed & required!) and one for the TE, of course. Not cutting the big hole in the fuselage stiffens the fuselage...tho the wing should also...maybe a toss-up?
Another thought, is that a foam wing (with plywood stub spars, which is normal if wing LG is used), and a bit of extra wood at the TE, would make a real good match for a 2 piece wing arrangement. Mounting the bellcrank and hooking up the controls would remain a bit of a challenge to solve, but that's what modelers do!
