General control line discussion => Open Forum => Topic started by: Dave Moritz on August 12, 2018, 09:00:18 PM
As a dedicated builder & sometime flier, I've so far been content with constructing and flying easy-going C/L models. Recently though, I had a hankerin' to up my flying game a bit and try some aggressive moves in the flight circle. That didn't end well. A pretty model that I'd stick-built from plans and finished with silkspan was a total loss (though the engine survived). Now I'm back to flying with another nice model but am hesitant to take risks.
What I'd like to do is build (or buy ARF) something that can be repaired at the field. Probably foam wing and purely functional design. For power, I've got an Enya .15 and a K&B .20, both very good runners but the K&B is heavy. Would like to use 52' lines.
I've read elsewhere that a simple, crashworthy plane for learning need be nothing more than a plank wing, stick fuselage and equally simple empenage, so long as it's balanced & proportioned rather correctly. As for ARF, not sure if anything is available. Apparently Phil Cartier's Corehouse offers or did offer models that would fill the bill, but couldn't find anything to match my engines. Finally, I've got a SIG Skyray kit and OS 25LA waiting in the wings to be built. However before subjecting that to possible sacrifice, I'd like to be able to do loops, decent wingovers and inverted with a measure of confidence.
So am looking or suggestions here. I've got foam core, aluminum square tubing, fiberglass, epoxy glue, thin ply, balsa pieces and all the correct hardware for building a plank model. Alternatively, I could come up with the scratch to buy a suitably rugged ARF if such could be found. Finally, I could go ahead with a not-too-fastidious Skyray build and let it and the OS 25 suffer the consequences.
Fire away, good gents, as I surely could use whatever wisdom you might offer. Thanks!
Dave Mo....
PS: No club in the area to help me through this phase of the hobby.
It sounds like you want a Gotcha Streak from Corehouse.
Hello The Gotcha Streak sounds good and a bigger 35 can be had cheap but there are also many 15 size planes that would work well with your Enya 15 or K&B 20 . I used a combat wing (5th Revolution) with a fuselage for my wife to learn aerobatics. Same model then helped my then my sons too.
A good example of this is the Spitfire by Dave Cowburn see:
https://outerzone.co.uk/plan_details.asp?ID=9565
It can be built with a foam or built up wing and is designed for combat so has the rugged qualities you seek!
Regards Gerald #^
My opinion is that it's easier to repair simple built-up models than most foam-based models. As long as you have Hot Stuff and packing tape.
My suggestion on how to proceed is pretty well documented. You want a simple model that you can repair, and provides adequate performance. Most trainers that use vintage engines are absolutely terrible. I have used a balsa clone of a SIG Skyray 35 for many years now - nominally the same airplane, for about 25 years. I flew it with several vintage engines and while I could get it through complete stunt patterns, it took a lot of effort and, not to be immodest, I was pretty good at model airplanes long before I built the airplane. It could be done but the skill level required was very high. I replaced the engine with a modern engine, and it was like gravity was turned off, it was so much better. The airplane is fully capable of winning any Advanced contest in the right hands, and I think my high score with it is up around 560 points.
The other thing was that the airplane started off with the stock kit parts - i.e. lots and lots of lite ply, which is both heavy and relatively weak, and also has no "give" to it. The first time it crashed, almost every rib in the airplane broke, and there was no fixing it. I rebuilt the airplane with balsa parts, and it has since crashed at least 40 times, and most of those resulted in no more than a damaged prop. The light wing made it perform *slightly* better, but it was vastly more robust, and most of those crashes resulted in no damage other than the prop. I had to rebuild it a second time, because the Monokote had turned to glass in 25 years in the warm California sun, and just crumbled in a light pancake. Any time it was damaged, I just glued it back together, right at the field, and flew it again.
My suggestion is a medium-sized profile airplane like the Skyray 35, Flite Streak, Medic, or similar built from normal balsa with normal techniques. Elevator-only is preferred, because it's easier to trim, and getting it trimmed (particularly without any help) is critically important. Cover the wings and tail with Monokote/Ultrakote. Finish the fuselage with epoxy. Do a neat job, but don't go crazy - because you really want to build 2-3 of them at a time, all the same.
Power the airplane with a *stock* OS20FP ABC or 25LA. When I say stock, that means *all the parts that came with the engine*, *exactly the way it came from the factory*. If you can only find a 20FP or 25LA RC engines, that is OK, get the stock CL venturi and stock needle valve/spraybar assembly from Tower. You probably only need two engines, but set up all the airplanes to be able to switch them easily from a broken airplane to a OK airplane. Use a *stock* APC 9-4 propellor, and get a lot of them. Make up a couple of sets of .015x60 lines.
Build and set up the airplanes and engines, and *take them all to the field*. Pick one, start flying it. Don't hold back, push yourself to learn the maneuvers. If you crash, DO NOT pack it in for the day and go home. Save all the peices, put them in a bag or box and put it in the car. Get the next airplane, check your lines, or replace them, and just keep going. Continue until you are out of time, or out of airplanes. Take everything home, and fix them before next session. If you have a problem with the airplane, say it just won't run, put it away, get another one, and keep going. If you run out of airplanes before run out of time, then, take a box with repair parts (like Hot Stuff, 1/64 ply, packing tape or FAS-CAL, saw/knife/sandpaper, etc) and fix the airplane with the least damage. With thin Hot Stuff, you can just push a lot of breaks back together, have all the fibers merge in a perfect splice, and one drop of glue will fix it almost to the point you can't see the break.
The key is to *just keep going*. The tendency I see over and over is that beginners/novices encounter one problem, then just give up, and try to fix it for next weekend. That's the worst thing you could possibly do, because it both wastes your time, and also, makes you so concerned with crashing and maybe losing another week, that you don't try hard enough.
Listen to Brett! He's a National Champion and a very smart guy. If you really want to be successful this is the way to do it! I personally would recommend The OS LA25 simply because they are more available than the FP20 but either is a sure bet for reliability and performance!
The local Los Angeles CL guys talked me into flying controlline after many years of FF and RC glider. Did fly CL as a kid but never got past loops and lazy eights. They said they had a plane ready for me and so why not? Well the plane was a used RTF Ukrainian (Mezlik/Yuvenko) fast combat plane with an old Enya 35. I said they were nuts! Anyway, they got me on the handle, short tank with a streamer to slow it down, I was flying! It felt good, so longer motor runs, confidence increased, got jiggy and stuck it in the ground. The guys hosed it off and I was in the air again!
Bottom line- the RTF combat planes are really tough, relatively cheap and fly great! You do need to hook up with a local combat guy to source the plane and accessories.
Norm, who can finally fly upside down!
I've been keeping my wife in airplanes based on Phil Cartier's foam wings, and I got myself going with a Skyray and a Flight Streak. In my experience, the Phil wing plus Gorilla Glue makes it easier -- by the time you biff a Phil-winged plane hard enough to break the wings off, you've crashed hard enough to have a Skyray in itty bitty pieces, so you may as well pull the second plane out and fly that anyway.
Dave: either take Brett's advise and build up a bunch of Skyray airframes to run with your 25LA, or build multiple planes with wing cores from Phil. In either case, proceed to go to town with them. His suggestion about showing up at the field with multiple planes does work -- it's what I did when I could, and when I couldn't I at least had one at the field and one halfway repaired in the shop.
Note that his Gotcha Streak wings, without extensions, ought to do well with a 25LA. In fact, it's the motor Phil recommends for the Streak III.
What kind of filter do you use to keep dirt from going down the venturi in a crash?
Joe Ed Pederson
Joe Ed Pederson
Pantyhose
Ken,
Do you stretch the pantyhose over the top of the venture and keep it in place with a twist wire/rubber band or do you stuff the panty hose down the throat of the venturi?
Gee, I thought this thread was about me and you just spelled my name wrong. My wife has called me crash Kraft ever since we got married in 1959. I have the tee shirt.
I use small "O" rings or small plastic ties to hold the panty hose on to the venture. Cut the pantyhose large enough to go down the sides so that you have plenty to tie to. You can always trim it a little if you want to be neat after you tie it.
I have found it is better to ask your wife for an old pair than to have her ask where they came from!
A cross between This 'n' That , scaled to suit . 150% is 56 in 200 % is 72 inch .
As the combat wings can go in unscathed at the Ton , maybe on soft ground .
Youre in for a start . Been meaning to do one myself , amougst other things .
(https://static.rcgroups.net/forums/attachments/5/9/2/2/3/a2079514-18-F2D%20combat%20wing.jpg?d=1222147036)
(https://aerofred.com/data/thumbnails/71/Peacemaker.jpg)
Std size'd be eligibal for vintage/ classic Combat , here in Aus. & in G.B.
Just a standard F2? Combat Wing , with the .25 , on say a 9x4 or 10x4 prop , on maybe 60 foot lines , would get you through the schedule no worries .
Theyre availaBLE READY TO GO FOR A REASONABLE PRICE . oops . Grab a few and chuck a fuselage on one or two .
Or set up a foam cutter for leading edges. Nichrome wire & a reaostadt . Dunno if a Glow field box variometer'd work ?
(http://1.bp.blogspot.com/-Z6wRpk3V1pw/Tl4z4qbqX0I/AAAAAAAAAco/N0cJfQ_Z5dg/s1600/01.tif)
tons of drawings on google pictures . tho this is a ' std. ' that works good for stunt, a notch nose heavy , on longer lines .
theyre made of pine ( if youve got a bench saw ) & foam , bound with thread . Balsa Tips & ribs . Tough as old nails .
The coverings the stuff for library books etc , from the stationers . Abitious types buy a 100 metre roll . Its cheap . And Tough .
Heat gun to shrink , iron to seal . Almost un rippable .
That will certainly fly OK, but give no experience in building and repairing, and almost no applicable lessons or experience in trimming a conventional stunt plane.
They do trim them a bit . AND they get plenty of practise repairing them . Opps . S?P S?P LL~
H^^
H^^
AY YI YI! Stunt and RTF combat planes from the Iron Curtain, are not really the same path forward.
Thought this thread was about getting some air time? Meanwhile one could be building that Twister/Banshee or learning to fly inverted so the first flight on that plane you spent hours/days building isn’t trashed on its first flight?
Norm
Er , READING THE INITIAL POST . :P .
" Ab Initio " TRAINING . . .
(https://trademe.tmcdn.co.nz/photoserver/plusw/553266906.jpg)
(https://trademe.tmcdn.co.nz/photoserver/plusw/553266440.jpg)
(https://trademe.tmcdn.co.nz/photoserver/plusw/553266490.jpg)
(https://trademe.tmcdn.co.nz/photoserver/plusw/553266560.jpg)
(https://trademe.tmcdn.co.nz/photoserver/plusw/553266785.jpg)
And JUST AS WELL , Too . LL~
(https://thumbs.worthpoint.com/zoom/images1/1/1110/13/nib-airsail-sportsman-l-trainer-sport_1_490d13a3e70475acca5ca0b7133ce37a.jpg)
SCALEING these to say 36 span , or 48 in . Proportionately . Would get that for the .25 . Use a 9 x 4 or 10 x 4 , or 3 , prop . to keep it slow .
The In Line Flat Underside bit , all lined up , less bits to glue back together after a wipe out though . Dont Forget the TIP WEIGHT .
' WE " had just about given up . Given up last weekend of the school holidays walking down the reserve to break it again , Baby Bee in it .
So cut the hideous string lines down from 25 Ft to 15 ft, to fly on a vacant lot . And Hey Presto .
It ripped around Lines Tight and FLEW . Rather than doing a slow roll to the left , as it went up and in , toward the pilot / budding aviator .
Not so budding by that stage, though plenty of repairs had been required . We wont mention the Kiel Kraft rubber model prop on it .
Or the Blade Shedding .
OTHER THAN TO SAY , keep your face OUT OF THE PROP , and shed blades go OUTWARD - Peripherally & Fwd . a bit .
That Lesson was learnt EARLY , Kepping your fingers out is harder . Pig Skin Gloves from building suplies arnt a bad idea .
Prop on backwards , rear face forward , was an old ' slow it down ' initially , trick . Still applicable .
A few coats of dope ( Auto Lacquer o.k. ? ) sanded , then TISSUE doped / lacquerd on , will make it MULTIPLY STONGER .
These swine flying real slow putt around Nose Up , so giving you delicate control sensitivity , or itll sag into the deck .
Another lesson of early UNDERPOWERED trash .
Also strapping a 100 Mill / 3 Oz squeeze bottle , srtrapped on the outer wing , would have a Moelair Gnat up for most of ONE HOUR .
The young turkeys in Our Club at Torbay nearly all learnt to fly in two or three tankfulls one sunday afternoon , with the Mills . 75 Gnat.
Again , . . . the first 20 minutes were a balance , thrust / drag / weight ,till fuel burnt off , requiring delicate control , to much up & it'd hover .
H^^
Like every kid into CL when I was growing up we all flew combat and stunt and yes I have flown the pattern with a combat plane but I would have never thought of learning to do it on one. So much of stunt is muscle memory and timing. Get something that flies roughly the same lap times, turns about the same and is subject to the same problems in wind that the PA ships are but doesn't ruin your year if you crash it...and you will crash it.
The GNAT was pretty much a PHANTOM MITE , the 1948 Phantom Here ;
(https://outerzone.co.uk/images/_thumbs/plans/1397.jpg)
Mite :
(https://aerofred.com/c_images/img.php?src=./data/thumbnails/71/KK_Phantom_Mite_1948.jpg&q=90&w=330)
(https://outerzone.co.uk/images/_thumbs/models/881.jpg)
(https://thumbs.worthpoint.com/zoom/images2/360/0612/24/keil-kraft-phantom-control-line_360_562fda78a9f56c4e182dc6b7a8a8617b.jpg)
Were all the rage for RACING , internationally , turn of the century .
G Pics gets link for downloads .
Scale as per Sportsman . Youll get more pieces per crash . with one of these .
Then you want advanced trainer . Read ' Combat Wing ' . S?P
Simpler the simpler to repair , maybe. With BALSA Anyway . FOAM dosnt generally repair well .
Building these "roundy-round" airplanes is not a great idea, you outgrow them in about 3 flights, learn nothing about flying, and then what? Hangs on the wall until you die.
Of course, anyone can build anything they want, I have my suggestions after watching and helping people (and myself) make mistakes and mis-steps for 50-ish year. We have had WAM "Grand Champions" who couldn't do anything but 45 different variations on flying level, so what do I know?
The OP Here:
Wow, but is this a fascinating discussion! Each time I get my mind around a response, something new, different and equally valid comes in and derails my plans. Gotta love it, though!!
Many thanks to each of you for experiences and thoughts. I'll be watching this and get back with my plan!
Dave Mo...
The OP Here:
Dave Mo...
Some advice here is more equal than others. Just keep moving forward. If you can handle the level flight thing but not much more then you are probably ready for a stunt trainer but you are not ready for a combat wing!
Good luck - Ken
I am in the camp that followed Bret's advice on several of same or similar planes for flying/training day...Dork one...pull out another
Not having any success at warp free balsa wings---- I decided to let Phil Cartier (Core House) supply me several RST (Rugged Stunt Trainer) kits..at the time were $69 each now I think they are $89...I also bought extra sets of wings...still unused
they are as near a ARF as can be had with a build time of less than 5 hours after you do the first one carefully...first one took a bit of head scratching and relearning some build techniques, glues, and fretting way too much on final finish so a full weekend to build
PURE !!!BBTU OS FP and LA 20s and 25s power my RST fleet...I have figure Nine dorked in honking fast ... set aside, fly next in line then cleaned the dirt out of the dorked one... NO broken fuse, wing or stab
Not much of any serious trim work is needed...they do NOT have adjustable lead-outs...Follow religiously Phil's set up in the instructions
I added Erik Rule Aluminum LG and 2 1/4" wheels
http://home.earthlink.net/~philcartier/index.html
Phil's web site has always been a mess...like a few other cottage guys...Just call the man...he will take care of you
Opps , looks like I missread that . Must be the Computer ! . :-X :-[
The ' Scale Racing ' Good Year Racers , in the Appropriate Section ,
Would rip around snortingly with a L A 25 , a 8 x 6 should see the ' TON ' easily .
If you want to get all artistic & have something durable .
Most with two elevators & 45 degree control travel will manadge a loop & rip around inverted too , 60 Ft lines tho , for that & a .25 !
The Old GOLDBERG Shoestring / Buster / Cosmic Wind , are a bit more durable & fall together Easier than th Brodak Replicers ,
Tho sometimes weigh a ton , as they did a deal with the Turks & some are made from parts of the Ark . !So a tad heavy , Tho Not All .
Allof them Mid West Profile suckers are in a Similar Veign . The SHOESTRING plan is downloadable from those Hippocket or sim sites ,
And is a bit of a classic , Suitable for ' Dogfighting ' in the manouvreableity Dept .
Or theres several ( Thousand ) other choices .
Greetings All:
Super discussion here, and lots of generosity.
First, Norm probably hit the nail on the head most squarely. For the short term, I've got an absolutely wacky and maybe fun craft in mind for the Enya .15. I hope that it can be put into the air (and dirt) numerous times during the remainder of the flying season. I'll be back seeking further feedback on that project.
Brett and others have convinced me that multiple planes are needed in order to progress. By the way Brett, what is Hot Stuff and where can it be had?
Matt: Think I'll pass on the combat wing suggestion. I thank you for the beauty of your nifty full-fuse plans. Also appreciate your non-linear communication style!
So, how to decide between stick-built and foam? Well, I've already got on hand a BBTU in the form of a Skyray kit and stock .25 LA motor. It'd be just a question of building two more Skyrays and sourcing another .25 LA. And there's time to build this winter. On the other hand, there's something about a foam wing that strikes me as inherently expendable and thus subject to fewer regrets when it plows into the ground. Sounds like the .25 LA would work for the foam also. Finally, there are budget considerations.
Well, it looks like I'll soon be making a call to Corehouse to see what Phil can offer. Then I'll break open the Skyray kit and figure out how much additional lumber and supplies will be needed to give me a triple header there. Decisions, decisions!
Thanks again for each of you who took time to respond. All the best to all the rest!
Dave Mo...
... By the way Brett, what is Hot Stuff and where can it be had? ...
CA glue. Brett is showing that he is a Beginning Geezer by referencing an obscure product line that hasn't been well-known for years. To my surprise, though, they still exist (http://www.caglue.com/). According to Satellite City, the purveyors, Hot Stuff is still the best stuff to be had. They may even be right. In the mean time, CA glue from the hobby shop (which is almost certainly rebranded Dave Brown stuff) is good enough.
It's not a bad idea to get the little tubes of one-use Crazy Glue and keep them in your flight kit -- one real problem with CA is that it hardens once the bottle is opened. Crazy Glue is inferior glue in general, but a newly-opened tube of Crazy Glue is way better than a bottle of the World's Best Glue that's been knocking around in your flight kit for a year.
Be kind - Brett may be a beginning Geezer but he will be in plenty of good company once he advances to intermediate. I flew a lot of free flight when Hot Stuff hit the hobby. It changed everything. Most of the grocery store CA's are inferior to the hobby brand(s). You need a thin penetrating and a thicker slow drying - slow? When did 15 seconds become slow? I just grab a small bottle of both and some kicker (spray to cure CA when it doesn't want to) and throw them into a dark corner of my flight box and take them out (hopefully unused) when I get back. Now here is one that nobody has mentioned - the flight box.
Invest in one of the roller kinds that have a bunch of tool bins and places to put stuff. Northern Tool carries a great one for a reasonable price but I have seen better for a few $$ more. When I go out to fly I have an extra of every doo-dad on my plane, most of the props I own, extra lines, batteries and every tool you could need to make a repair. It is ready to go at all times and I just load it into the car with my planes (plural) when I go practice. We have some guys that are better equipped than the local hobby shop. Mine has a place to carry my lawn chair and stooge. Properly placed, they also make great references for intersections.
It's a specific brand of Cyanoacrylate adhesive - the first that was marketed to modelers. You can still get it, and I still think Hot Stuff "Super T" is the best "medium" cyanoacrylate. But, any generic cyanoacrylate is adequate for gluing balsa together. There are only a few manufacturers, maybe 3, and it all comes from there regardless of the label. Most hobby shop brands are from "Bob Smith", Zap I think makes it, and Satellite City gets it from whoever too over from Eastman (maybe Loctite). There are industrial versions, with much less stabilizer, that are arguably stronger, which is probably moot, since even the stabilized versions are more than strong enough when used properly - and the stabilized/consumer/hobby versions last much, much longer open at room temperature.
I would highly recommend searching for the links to Bill and Bob Hunter's how to build with Hot Stuff videos, they are absolutely chock full of nuggets on how to best and most efficiently build using cyanoacrylate, with a lot of pretty innovative techniques. I was very surprised when I watched them again (after maybe 40 years( at how much of their techniques I used, and had forgotten where I got them. They are linked on Stunthangar somewhere, they are well worth your time.
try here:
https://stunthanger.com/smf/building-techniques/laminating-glue-(fuselage)/msg317971/#msg317971
Brett and others have convinced me that multiple planes are needed in order to progress...
...Then I'll break open the Skyray kit and figure out how much additional lumber and supplies will be needed to give me a triple header there. Decisions, decisions!
Dave Mo
Dave, I drank the Cool-Aid and scratch built three Skyrays.
(https://s5.postimg.cc/87aarckx3/Skyray_35_Trio.jpg) (https://postimages.org/)
I just crashed the first one this Wednesday. I should have brought two planes to the field, but I'd hurt my ankle and figured I'd be doing good to fly one plane. Well, I didn't do too good... The plane got behind me, and before I could get my orientation back, it crashed. Video showed it hitting almost straight down (I use my hatcam to record each flight so I know what happens when I crash). I didn't take any post-crash pictures, but it was pretty beat up. Engine crankshaft bent and one mounting lug broken off, muffler bolts sheared, several ribs broken, inboard leading edge broken where center sheeting ends, outboard lower spruce spar broken where center sheeting ends, center sheeting ripped out top and bottom, trailing edge broken at both sides of fuselage ( nose stopped, but the wings wanted to keep going), fuselage split horizontally about six inches from the wing t.e. back, elevator broken where control horn is mounted, and the large wing skid I was using for a tail skid was sheared off (?!?). I even punctured a hole in the clunk tank, which is a first for me in 35 years of modelling. But the stab and rudder were unscathed.
I was flying the pink one on the assumption that it would be the first to go and most expendable, and I'd get to move on to the more manly colors after I crashed it. Well, the boys at Delta Park insinuated that if I were a real modeller, I'd fix it up and fly it again instead of throwing it in the corner to wait for repair "someday". So, crashed on Wednesday afternoon, repaired and ready to fly on Friday morning. Unfortunately for me, my wife scheduled the painters to come out to the house on Friday without consulting me, so I couldn't fly the repaired plane. Maybe I can get out next Wednesday. But, these Skyrays are easily repairable in a short time.
Mark
Joe Ed Pederson
Use a "Dork tube" - short length of silicone tubing longer than the intake that folds over upon impact.
Lots of sage advice above without a doubt. I don't know if my comments below will carry and weight at all...and that's o.k.
I don't fly comp. But I have loved building nice looking (at least to me) airplanes since I started in c/l back in the early 70's. Even though we might crash them my brother and my models always had a certain look about them that we thought was pleasing to our young eyes....we did not fly junky models. Each model was an attempt to better our building and finishing skills within the realms of the tools and equipment we had at the time... read: a few colors of Testors dope and some masking tape and a good paint brush.
During our "self taught" years of c/l a big piece of the ability to progress on the flying side of the hobby was knowing that the airplanes we were flying "could in fact pull a loop"or "fly inverted " (without the engine stopping) etc. There was this "mental unknown" attached to any advancement in the flying. Most models built to plan spec could out fly the kid that was holding the handle if only that kid had the balls to try and make it "pull a loop" or "fly inverted" etc.
So how do you gain the confidence in both the model and then your flying skills? Having an experienced pilot fly your plane and do a loop etc could help you at least know that "yes my model will fly a loop", but you still have to get past your own mental block about doing it. We did not have that kind of test pilot available to us, which in a way only added to the excitement and the feeling of accomplishment we all got as we progressed. Wow those were some great days.
I think it is possible and probable that when you attempt and succeed at having done a loop or having flown inverted, regardless of the type of airframe used...you have in affect knocked down one of those mental barriers that was holding you back. So...a foam slow combat job,..or a rtf combat wing from the iron draperies, or a plank wing trainer... will no doubt get you past that mental "will it do it" "can I do it" block once you've actually managed to do the maneuver. With that mental block torn down you will have gained much needed knowledge/feel/experience about what is required of both you the pilot and how your model needs to perform in order to fly that same maneuver with each proceeding design you build.
The loop was for me and my flying friends sort of the starting point. Fly loops until the lines are so twisted you can't hardly control the plane "Why is that we wondered? ;D The next flight altering move in my mind is inverted...from here on out all other things are possible. Like the loop, inverted presents yet another metal hurdle to get over. Like most things...having done it once .it's like "mind blown. :o why did I think this was so hard?" kind of thing.
We still went on to attempt to master the building and finishing aspects of the hobby to at least a point where we continued to please ourselves. But that was always part of the way we approached the hobby.
The path to getting there of course may be very different for each of us. Lots of good advice up above for sure...but even getting it wrong can still be a whole lot of fun and a bit of an adventure.
Thanks for listening,
A brace of Profi K12/19 Diesels fitted with Dork tubes for British Combat.
(https://stunthanger.com/smf/index.php?action=dlattach;topic=51077.0;attach=289125;image)
Tony:
Well written advice, so many thanks to you for taking the time to combine a bit of reminiscing with your years of experience.
I intend to start on some kind of hybrid stick and foam crash craft for the Enya .15 previously mentioned. If I can post photo's here, so much the better for garnering advice.
Cheers,
Dave Mo...
Mark:
Sorry to hear about that nasty crash with the pink Skyray. At least you got it back together so that it can see action again. Hope you can figure out what happened so that you avoid that technique in the future.
So, what are you using to power each of these? All the same-sized motor, props, fuel and fuel tanks?
Thanks.
Dave...
Dave...
Dave, the planes all have OS .25 LA-S engines spinning APC 10-4 props with 4 ounce clunk tanks, although I only fill the tank with 2 ounces right now as that gets me four minutes of run time. I used the same hardware that would have come with a SIG kit. This gives an elevator throw of ± 30 degrees. The yellow plane weighs 28.1 ounces, the blue 28.7 ounces, and the pink one was a pig at 30.4 ounces. With the repairs, it is probably around 31 ounces, now. I didn't weigh it after finishing. Maybe I'll weigh it when I get back in town in a couple of weeks. But at 30.4 it was more than responsive enough for me, and with an engine out it glides well.
Mark
Interesting thread, anything labelled "Trainer" simply teaches one to stick part A to part B - not to fly with anything that approaches confidence.
For me, an undercarriage is essential as take offs and landings are the very first things that must be mastered, hence a combat wing fails miserably here.
And the model must be capable of a controlled glide, yet to see a sheet wing model do this well. .
I would take a guess that you may have not seen or flown a Guillows Profile Trainer III. It fits your landing gear criteria but also disproves your "...controlled glide, yet to see a sheet wing model do this well" comment. Granted, for a "sheet wing" it does in fact have an airfoil shape carved into it. We flew the large version of this thing back in the day. Amazing dead stick glide. As per my comments above, we were learning on our own at the time. We managed loops and wingovers with it but not much else. I never went inverted unit I completed a Fox .35 powered Goldberg Shoestring around 1976-77. A great profile combo (IMHO).
(https://stunthanger.com/smf/stunt-design/'airfoils'-are-they-really-important/?action=dlattach;attach=243212;image)
I would take a guess that you may have not seen or flown a Guillows Profile Trainer III. It fits your landing gear criteria but also disproves your "...controlled glide, yet to see a sheet wing model do this well" comment. Granted, for a "sheet wing" it does in fact have an airfoil shape craved into it. We flew the large version of this thing back in the day. Amazing dead stick glide. As per my comments above, we were learning on our own at the time. We managed loops and wingovers with it but not much else. I never went inverted unit I completed a Fox .35 powered Goldberg Shoestring around 1976-77. A great profile combo (IMHO).
My IMHO too. That Shoestring, Buster and I think the Cosmic Wind was a STOA combination in the 60's. I had both the Shoestring and Buster and loved every "burp" from my Fox 35. The Shoestring taught me to never let your lines go slack taking off from grass and the Buster taught me that you can't start an 20' outside loop from 15'. Lessons that I still practice today! (Either one of them will out glide the Guillows Trainer)
That's one of the points I have made on several occasions. it makes nearly no sense for every individual to build this sort of airplane as a "trainer". You build it, that's easy for almost everyone, then you fly it 3-4 times before you master takeoff, level fight, and landing, and then you have learned just about everything you are ever going to learn with that airplane - and probably a lot of bad things, like, flying in even a little bit of wind is really hard and you might crash, and that you need to give full up and full down just to get it to do anything.
It makes a lot more sense to me to have these around as "club" or "group" trainers, haul it out when people want to take a random try at control line, or when someone is learning, but have them move on to something more responsive after no more than one flying session.
BTW I don't know where the perception came from that these airplanes cannot "glide". In many cases, they glide very well (heavy, but relatively low drag), and with the application of a little "arm", can be flown indefinitely after the engine quits. When I had this sort of airplane as a "trainer", I got bored pretty quickly, so I probably flew more total flight minutes with the engine off than with it running, just for something to do. Get a minute-and-a-half engine run, then whip it until you get tired.
They do have a problem landing on grass - usually, instant flip and tumble end-over-end.
Its perception thing Brett, every sheet wing model that 'I' saw was very nose heavy (because that was 'safe)', had a high wing loading and were poorly trimmed because it was most peoples first model and literally a balsa Airfix kit.
Cox trainers were especially bad in this respect and almost made me give up when I was a lad.
Obviously this could be remedied with knowledge but we are talking about what is marketed to and attracts a beginner.
Brett,
When I say "and not much else...never went inverted until the Fox.35 Shoestring..." I'll clarify the statement so there no misunderstanding. The Profile III may have been up to the task but we were at that point not capable as pilots...er so we believed. Again,. Learning on our own, no club to touch base with etc. We did progress over time, but not at the rate I think your advice would indicate that we might have...we were much slower then your "crash/repair/keep going" program would allow for. Heck..we were kids just having fun.
As the models got more complex (by degree) we did get more daring with the older models and they became somewhat expendable. With competition not our main goal (back in those days we did not even think about it) we just spent many an afternoon boring holes in the sky and enjoying the smell of castor oil and K&B 100 and 1000 fuel and the company of like minded friends. I often think that our parents might believe that as long as they could here a motor running over at the ball diamond that we were safe and staying out of trouble for the most part.
Hmm...maybe I tell a half truth...we did compete....but only against each other. With each model I know for sure that I tried to build a better model each time as compared to my buddies.
It is obvious that I am not and will not be a serious competitor. That said, I love reading the tales of gents like yourself and others that compete at the national and world levels. An unbelievable amount of dedication and time, energy, practice, etc. expended to reach that level. My hats off to you all.
The Guillows Trainer is a super piece for teaching new flyers....I bought two well worn pieces from Mike Turo years ago....the .15 powered one exploded on the deck of the Intrepid after an unplanned wingover.
The .35 unit still exists.
It's important that trainers are not too pretty, otherwise an trainee feels bad when they dork them. My belief is that newcomers shouldn't build them....their usefulness soon goes away after climb. dive, and spinning around for five minutes is accomplished.
The Skyray seems to be the next progression. Easy to build and easy to repair. I would shy away from foamies as they tend to make it look like it's snowing when crashed hard.
Have fun
Brett when you say finish the fuselage with epoxy, do you mean just clear epoxy like West Systems?
Thank you
You could, but no, I meant 2-part epoxy paint, easy to apply, even OK with a brush, and durable.
OK..thank you.
If you're talking the USS Intrepid Carrier, well, that's a story I'd like to hear.
One and the same
It's been about 15 years....
We (the GSCB) got down there on an incredibly hot day.....flew mostly 1/2a's
Even with short lines, the Guillows 15 flew past the edge of the deck.
Kid overpowered the instructor.....wingover.....boom....big crash
Brett:
Regarding the Skyray trey, I've got one OS .25 LA. I'll keep an eye peeled for more, but I'm finding more OS .20 FPs and OS .25 FPs on the market. If the OS .25 LA is not available, which of the other two would match the lineup better?
Also, where can one get two-part epoxy paint?
Thanks.
Dave...
Brett:
20FP is probably a better choice than a 25FP, although both are satisfactory. Both have more than enough power, the 25FP perhaps too much for this application.
Two-part epoxy is here:
http://www.klasskote.com/stock-color-kits
Looks expensive up front, but saves airplanes over poor solutions like dope and various spray-can stuff.
Remember, we're talking to a beginner here, who wants to learn the maneuvers. Crash resistant, or better yet, a plane that bounces will let a pilot learn what up and down do, how to do the maneuvers, what the wing does much faster. Then they can build an advanced trainer that can do a reasonable pattern.
Allow me to reiterate but also add my own experiences flying these engines in the same plane back to back. I had an LA25 in my boxcar chief and it was borderline not enough. I switched to a 25FP and now it's a beast.
So in a sky ray, I would suspect the 25la will serve you well. The 20FP would be stellar.
The 25FP would be a little unnecessary.
Well good gents, here's the plan as gleaned from all of the forgoing input. Neither the cheapest way to go nor the priciest. It gets me into the air for some late Summer flying. At this point, don't think competitive flying is for me (but, subject to change).
1) Snag a couple of recommended OS motors off the Bay (25 LA and 20 FP, both used).
2) Talk to Phil and order a foam wing model from him (a Streak of some sort).
3) Build from kit a SIG Skyray for use with the 20 FP motor.
4) Install two-wheel landing gear on each model for stooge launching.
5) Fly at local ball diamonds, launching from smooth gravel and then stepping back to fly over grass. 60 feet of .015 lines.
Given the construction times involved, I'll likely start out flying the (more bounceable?) Streak while constructing the Skyray. I'm hoping that packing tape and glue will get me back into the air shortly after each crash of the foamy.
As you can see, this is a hybrid of the two suggested lines of thought.
Notwithstanding serious flaws in this plan, here we go. Thanks a bunch for the advice!
Dave...
To complicate things, there's reported to be an old bad 25LA, and the new good 25LA. Certainly, I have a 25LA and a 20FP, and the 25LA pulled my overweight Skyray around better than my FP did -- so the FP went on my overweight Ringmaster (yes, there's a distressing trend here). AFAIK, there isn't a good way to tell if you've got an old bad one or a new good one, except that (again, AFAIK, grain -o- salt, all that) they switched to the non-painted motors after they did whatever magic they did to make 'em good. But the new good one I have is blue.
I have a thread in the engine section about this. The color was never a differentiating factor. I believe it was only the crank.
I agree with the above! #^ Phil's RST is the plane for beginners! ~> I strategically reinforced my wing with drywall tape. I have not been able to break the wing but I have bent the front of the fuselage a number of times. I am not sure that the RST is on Phil's website; you may need to just call him & order a couple. Mine has a FP 25, 1/8 wire landing gear, & 2.5 lite foam wheels, adjustable leadouts, rusteolum paint. I am not a good flyer. I can't do the full pattern. I've flown Flight Streaks, R-masters, Sig Banshee & Skyray, Combat planes, & trainers. They all fly well as trainers. The Corehouse RST flies as well as any but is the most break resistant & easiest to repair! Once you are comfortable with the RST, Phil cuts the leading edges for the TEOSAWKI, Pipemaker Mike has posted plans on this site for the Teosawki. The Teosawki is an RST but all grown up, needs a 45-46 engine.
Beginner Tips to keep the plane out of the Dirt. An RPM tack for consistent runs, An easily reset kitchen timer to time flights. My crashes are poor engine run or run out of fuel. The tack & timer have minimized this problem. An O-ring & a piece of 1/8 green pre-airfilter from the small engine shop works a bit better than pantyhose.
Indeed Phil Cartier is a class act. I called him and made the arrangements for a Streak RST - a very nice kit with well-formed styro wings was quickly delivered.
Tim: As far as the OS LA .25, I've got a blue one and have no problem getting 12,000 out of it on an APC 9x4. So maybe I've got a good one. A plus is that it's the same weight and mounting hole pattern as my OS FP .20 (stock mufflers included IAW Brett Buck).
Fred: Agreed, Phil's kit requires just the right amount of problem-solving to make the build fun. I love it!
John: Lots of good tips in your response! Not sure how you are deploying the drywall tape, but suspect it is on the wing's leading edge? I'll take your tac and timer advice to heart after I give the foamy bird its maiden flight. I especially like your suggestions on follow-up models and the green air filter material.
By the way, my plan is to build the RST and Skyray with single nose wheel landing gear in order to keep weight down. I launch with a stooge that employs a U-shaped padded gate that pivots forward upon release. The padded U is in contact with the front of the horizontal stab. Am hoping that the stab's pressure against the pads will negate the tendency for the ship to roll while it's still in the gate.
So that's it. Thanks again.
Dave...
http://necn.homestead.com/News3.html
Good tips, see the PDF file for placement & use of the tape. The superlite drywall patch is a nice trick to finish the foam before covering; you sand most all of it off. The only thing I did to re enforce the leading & trailing from dings & dents was an extra layer of Phil's covering material. I did need a small piece of aluminum (lid from cat food can, trimmed square) as a trim tab on the outboard wing. I must have produced a bit of a warp along the way. Love the RST! When using a stooge, I have put a length of 1/16 wire as a skid on the inboard wing tip to keep the wings level on take off; an old racer trick.
I would just get the plans, or build a second one out of balsa instead of plywood/spruce, because the plywood version will self-destruct beyond repair on the first significant crash. The balsa version will last much longer and will not destroy every part in the wing at the slightest whack.
John: Nice tip to help out on the stooge launch! In Phil's instructions for the RST, he makes no mention of outboard tip weight. Unless I misunderstand the design, I'll install something around .75 ounce. By the way and with apologies to all of the good aesthetes out there, I intend to finish the plane in a purely functional manner with crashworthiness first and a pattern that distinguishes between the upper and lower part of the plane. So probably white paint with some black over the SLC. I usually fly alone (no audience, or at least none until I can figure out how to do this sport without bringing it shame). Thanks for your help!
Brett: Glad you clarified the Skyray ply rib question I had in the back of my mind. Think I'll cut new balsa ribs and use them for the kit build; the ply ribs will make good tinder for my wood-burning heat stove. Though if someone wants them, I'll gladly place them in the mail after I use them for patterns.
So it looks like I'll be hitting the circle next Spring with two crashworthy craft.
Don't fly alone because you don't want to be embarrassed. n1 All of us had to learn and simply being in the company of expert, or even simply better fliers speeds up that process big time. All of us can remember when just going home with the same number of planes that you came with was a major accomplishment. In over 60 years in this sport/hobby I have only met a handful of people that would not welcome you at the circle. y1
Dave, I go to contests so others will always have the ability to say, "well at least I'm not that guy....."
LOL - I do the same so others will be able to proudly claim that they didn't finish last!
baraboo?
on hand stunt trainer?
"So it looks like I'll be hitting the circle next Spring with two crashworthy craft.".........confused I am
What is wrong with next weekend..?...Hurricane Fol is no where near you.....
BTW two of my Three RST....have Removable wing assys
The one inch wide 1/64 ply saddle in the 1/2" fuselage is plenty to hold the wing properly orientated with a inboard strip of Gorilla tape
The controls are attached to the fuselage
Inboard strip of Gorilla tape...thunk on this.. the gooey exhaust is all on outboard side of fuse and wing.....
I fussed and fussed with first RST filling the foam wing...sanding...fussing trying to make look pretty.... pure waste of effort
2nd and third are simple rattle can Rustoleum fuselage and tail...Water color paint on bare foam wing than then the SLC
single wheel gear is OK
BUT the short gears from Eric Rule RST are cheap and work just fine with OS 20, 25 Power
Part Number: PLGS
RSM Price $13.99
http://www.rsmdistribution.com/index.php
Gents:
Ah, down to the nitty gritty with a bit o' good-natured chiding!
Ken and Dane, I'm so vain (poetry - ha!) that I don't want potential control-line converts to see me plow the fields. But, I'll get over that and perhaps someday replace youse guys at the contests! FYI, I've every reason to believe that I'm the only CL flyer in town & 'round these parts. Milwaukee has a good club, though two hours' away.
What can I say Fred other than thanks for the great tips on the RST. They were just what I was looking for as Phil's kit directions point towards a refined model. Can't say that I blame him, but I'll be groovin' on yours to speed up the build. I already glued blocks in the RST fuse for single gear, but will use Eric's for the Skyray.
Much obliged to all!
Dave...
RTF combat planes, trimmed nose heavy, and other similar foam wing designs can take a terrible beating and are usually easy to fix.
Flown over grass, if possible, they are very adequate to learn how to fly all the pattern maneuvers. Lots of older folks started with Ringmasters, Flite Streaks, and Shoestrings. Once you can fly all the maneuvers, starting in the right place, putting the loops and corners in roughly the right places, then it's time to build a more capable plane that will fly more precisely.
I can't count the number of intermediate and advanced flyers I've seen that can't fly recognizable maneuvers or recover from a gust of wind trying to fly in a contest.
ps My maneuvers are usually not very good.
Hello All:
Just a follow-up to Phil's note. I built the RST he sent me in kit form and got in three test flights before temperatures got too cold. What a joy to fly! Best handling model I've flown yet. It handles beautifully with the CG indicated in the kit, responsive and predictable. Bravo, Phil.
I followed his exact instructions. Installed an OS 20 FP and 60 feet of lines. APC 9x4. Will try some risky maneuvers in the Spring.
I've attached a photo, but not sure how or if it'll show up in this post.
Dave...
Ah, now I see how the attachment function works!
D...
So F---ing ugly it's a work of art
and it flies more gooder than a lot of kit built birds
and it is durable....done right very durable
and it is EXPENDABLE!!
Last attribute is necessary to learn scary stuff like inverted
I am a hack pilot that is NOT interested in competition Stun flying and while I admire the pros...
I personally think, as an observer, that Golf, Bowling, Curling, Drone racing, and PAMPA stunt rate up there with me on porch after a Texas Rain watching the grass grow...mass quantities of Bombay Gin, Gentleman Jack, Grey Goose, Midelton Scotch is required
I can not do it, but a few of my aged friends must have a deep bong hit to watch the full 7 minute routine
David Moritz...Disregard the "ugly" above...compared to ANY appearance standards...even my very low standards...all three of my RSTs are -35 point planes.... grin... like several breeds of dogs or cats, so ugly they are cute and lovable....
Fred:
Ugly is what I was striving for, so it's nice to have my success acknowledged. Thanks a bunch! Come next Spring, I intend to meet with even more such esthetic success when I start taking some serious chances with it. Did I say that it flies beautifully? Well, it really does.
Regarding competition, you and I are bit of a like mind. High school sports for me was sitting second or third trumpet in the school band, and being quite content to boot!
All the best,
Dave Mo...
Ugly is what I was striving for,...
The first plane I built intending to get into CLPA for real was a Blue-Box Nobler. I covered it in really loud international orange Econocoat, figuring that it'd be butt-ugly and I wouldn't mind crashing. I made the mistake of using black trim. How was I to know that international orange and black would look good together?
Having a reasonably nice looking plane didn't keep me from crashing it, fortunately.
I didn't think you could enter a PAMPA event unless you could prove that you have crashed at least one blue-box in your lifetime.
